Fluid Capacity's
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by newyorkin, Sep 10, 2001.
  1. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Fluid Capacity\'s
    Hey all.
    I need to know the capacity of an NP208, and a corp 10-bolt rear. I changed them this weekend, but they're continuously leaking, so I want to know how down I am and was when I changed them (ran out of ATF @ 3 1/2 quarts when refilling the Tcase).
    Thanks yall!!!
    The diff I'm just curious about, cause I was in a rush and most of my gear oil ended up on my driveway while refilling...
    Ratch
    <a target="_blank" href=http://k5.8m.com>k5.8m.com</a>
    **Ever stop to think... Then forget to start again?**
  2. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Re: Fluid Capacity\'s
    The rear 10-bolt should take about 2.5 bottles of 80W-90 gear oil. I can't remember if those bottles are quarts or not, but it's 2.5 of those.
    Brian
    Click to see <a target="_blank" href=http://tx85gmcguy.alloffroad.com> My 85 Jimmy </a>
    Who put a stop payment on my reality check?!?
  3. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    I filled my front and rear 10 bolts up just a few weeks ago...2 bottles of mobil 1 in each...filled them to the drain holes. I guess it would vary a little depending on your gears, locker or whatever else ya have in there. Its not rocket science tho, fill them until the fluid is JUST below the fill-hole-plug and you're all good.
    Jason
    See the on-going build up of my '85 Jimmy! http://community.webshots.com/user/jekbrown
  4. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    The NP208 takes 4 ,5 quarts, the rear takes 2,5 botles like previously stated.
    <font color=red><a target="_blank" href=http://www.espen88k5.alloffroad.com>www.espen88k5.alloffroad.com</a></font color=red>
  5. Re: Fluid Capacity\'s
    I figure, my fluid capacity is is judged by how much is leaking out.
    Alot leaking? Full!
    None Leaking? Empty!
    Then fill accordingly
    '84 K5
    Chevy in my blood.
