fluid changes
Discussion in 'The Garage' started by Wishbone, May 10, 2006.
  1. Wishbone
    Wishbone 1/2 ton status
    Mar 6, 2006
    239
    Oklahoma
    How often should you change the front and rear differential fluid? Tranny fluid?
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    At work, I recommend both at 30K. Mitsubishi manual transmission fluid looks fairly clean at 30K(in everything but an Evo, there is just metal in that fluid, haha). All the 30K differential fluids I have changed have been nasty dark and smelly. Most people never change any of their fluids(except oil) with no issue. Personally I am a fan of changing them fairly often. Hell I flush brake fluid at work.
    Automatic Transmission? Ford and Mitsubishi recommend at 30K, Mitsu fluid is usually nasty by then, Ford not far behind. GM recommends at 50K from what I've found. Personally every 30k.
  3. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    for my truck that will see 3k max a year, it will be once a year.
  4. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    Every time you sink her in deep water..so once a week maybe ;)
  5. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    yeah, x2 on that. if you get 'er wet, repack the bearings and change anything that had the breather underwater.
  6. Kyle Strong
    Kyle Strong 1/2 ton status
    Sep 26, 2005
    280
    Eugene, OR
    repack which bearings?:confused: Wheel?
  7. Masiony
    Sep 2, 2005
    729
    Springfield, OR
  8. Kyle Strong
    Sep 26, 2005
    280
    Eugene, OR
    I thought those were sealed in the axle? I mean, I just repacked mine the other day, and it seems like it would pretty hard for water to get to them...
  9. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    you'd be suprised how easily mud and water can get in there. you should repack them every time you play in the mud, then let it sit.
  10. Zook4life
    Zook4life Newbie
    May 9, 2006
    3
    Lodi CA
    i got a 86 samuari....when should i change the fluids for the axles....and transmission...its a stick shift...so should i just get a new filter too
  11. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    filter? for what?
  12. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    1996 camaro... bought new.. 1 mile on it.. test drove for 2.. so since I left the stealership with 3 miles... I have put 173,000 miles on the car...
    same diff fluid, ps fluid, brake fluid... however oil gets changed every ohhhhhh 9-15k.... yeah i know that is bad for a motor.. look at my miles and tell me that :haha: .... at 75k i had the tranny flushed and it has been slipping ever since.... just cant hammer TOOO hard... v6 anyway....
    antifreeze got replaced recently... flushed via forced exit.... seems gm put this piece of crap adapter on one of the heater core hoses.. like a pressure release plastic unit with a spring in it..... blew apart.... and viola.... antifreeze slick for the person behind me :doah:
  13. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    I have heard (especially on a 700r4) that if you have neglected to change the transmission fluid every 30k to just leave it alone and not change the fluid. Seems if you wait too long and change the fluid at 80k or so you will just stir up a bunch of crap and kill the transmission.
  14. RootBreaker
    Nov 29, 2001
    5,117
    173
    seems over at camaroz28.com that the l480e has this 3rd gear problem.. known issue..... but yeah the fluid change didnt help
