Fluid for a Detroit Locker???
Discussion in 'The Garage' started by Smitty, Aug 12, 2005.
  1. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Finished putting a locker in the back of my '56 last night. I've been running synthetic fluid in all of my gear boxes and differentials for a long time. Will there be any disadvantages to running synthetic fluid with the locker? The instructions say to run the factory fluid, but nothing that I've owned ever came from the factory with synthetic.
  2. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Yeah, it will make it last longer! And probably work better...
    I've ran synthetic fluid with my rear Detroit for 4 years and it's still going strong...
  3. mrk5
    Apr 20, 2004
    12,331
    1,039
    Northern Colorado
    I've started running synthetic motor oil, brake fluid and power steering fluid, and I plan to switch everything to synthetic. Including the rear diff with detroit.
    I figure with all the fuel my truck uses, at least I can help cut some oil consumption by going to synthetics.
    IIRC my parents new Expedition uses synthetics in everything.
  4. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I e-mailed TracTech about the same thing not too long ago. Here is the exact reply. Dated 7/11/2005
  5. JonV
    JonV Registered Member
    Mar 17, 2003
    27
    Hesperia, CA
    Synthetics work well from low temperatures to high temperatures, and have high oxidation rates (last a long time). However they don't carry heavy loads. High quality enhanced petroleum products are excellent choices for hard offroad use.
  6. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Hmmm? Synthetics find leaks better than conventional oil. Dino oil's molecules are different sizes so in an oil leak, the large molecules will stack up and stop the leak. Synthetic, molecules are the same size, so you actually find more oil leaks with it. When you switch to synthetic, check your oil level OFTEN. You put it in an older engine and it can eat it faster than the normal stuff.
    My opinion? Dino oil in rear. You are going to have to change it every time you dunk the axle anyway, and I don't think you want to be spending that much cash...
  7. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    Synthetics don't carry heavy loads? Freightliner has put synthetic in their transmissions (Eaton/Spicer and Meritor) and axles (DS404, Meritor, Mercedes) since the late 90's from the factory.
