Fluid spewing from the t-case... help me out.
Discussion in 'The Garage' started by K5thatShmobs, Jan 31, 2003.
  1. K5thatShmobs
    K5thatShmobs 1/2 ton status
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Took the truck out yesterday for a little action, and by the time I got home I realized there was a pretty good leak coming from the t-case around the front driveline yolk. Is there like a seal or something I could just replace to fix this? Ive never delt with this before, so just looking for a little advice.
  2. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    You just need to replace the seal and it should quit leaking.
  3. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    Yes, there is a lip seal behind the yoke you can replace and will be gppd in the world. Ck the yoke and make sure there isn't a grove on it were the seal rides and lube up the seal with some grease before you reinstall yoke.
