Fluid under carb on intake manifold
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazerWheels, May 29, 2003.
  1. BlazerWheels
    BlazerWheels 1/2 ton status
    Feb 13, 2003
    587
    California
    When changing my plugs & wires I discovered a little pool of fluid sitting on the intake manifold under the carb. I am GUESSING that it is gas leaking from the carb. I am planning on having the carb rebuilt in early June. Is there anything else it could be??? I didn't think it smelled like gas, besides wouldn't gas evaporate?? /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/confused.gif
  2. BigBadJap
    BigBadJap Registered Member
    May 23, 2003
    76
    Alberta, Canada
    Coolant maybe?? I know some gm cars had a coolant line hook up to the carb or throttle body.
    I'd say taste it, but if it is coolant, that could render you dead...
  3. dyeager535
    26,975
    Is it oil? Not sure if it's "typical" for Chev's to leak that way, but it is on Oldsmobiles, the oil can "migrate" up the intake bolts if it sneaks past the "turkey tray" (full lifter valley/intake seal)
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I've had a couple of small blocks that would have a puddle of oil show up on the intake manifold. Removing the intake bolts and putting a dab of Form-A-Gasket #2 on the threads, then reinstalling the bolts fixed the problem on both. /forums/images/graemlins/cool.gif
  5. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    put your finger in it. smell your finger. rub your fingers together, do not dry them off for about 5 min.
    if it smells like fuel and dries off by itself leaving your skin dry its fuel. if it leaves your fingers greasy then it oil. if it smells sweet its anifreeze.
    if its fuel, check your carb and fuel line for leaks, oil, make sure your distributor has a gasket on it, cooland check your intake for cracks and not being sealed to the heads right.
    Grant
  6. BlazerWheels
    Feb 13, 2003
    587
    California
    Thanks for the info, I'll check it as soon as I get back this weekend.
