Flushing Auto Tranny Fluid?
Discussion in 'The Garage' started by laketex, Oct 2, 2003.
  1. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    Guy at Jiffy Lube showed me how fukkin dirty our ATF is in my wife's little car and wanted to know if I wanted him to flush the system and put new stuff in for $100. I told him I'd think about it. I HATE auto trannys and to tell you the truth, had not given this one much thought. (I'm 25, have owned 6 vehicles, but only 1 had an auto till this car) So what has to be done to flush the system? Is it worth the $100 to pay someone to do it? I already have a case of ATF in the garage from my last K5 so that part is covered....Let me know wassup! /forums/images/graemlins/eek.gif
  2. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Just change the fluid, that should help. Flushing is something those gaybates at Jiffylube do to take your money. /forums/images/graemlins/thumb.gif
  3. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    We have a flushing machine at work that pumps clean either clean fluid (when flushing the whole trans) or you can run something like mineral spirits through it (when just flushing the cooler and lines!). When just changing the fluid the normal way you only get about half of the old fluid out. I would consider it absolutely critical to have the lines and cooler power flushed if you were replacing a cooked trans.....
    With that said, I would have a hard time paying $100 to have it flushed. I'd say change the fluid and install a $3 drain plug in the pan if possible. Run the car a couple hundred miles and change it again.
