flushing out the my radiator what is the best chemical?
Discussion in 'The Garage' started by Redfrog, Apr 27, 2003.
  1. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    I need to flush out my entire cooling system, I have always just used the garden hose in the raditor for about 30-45 min. but the stuff that is in there right now I don't think will come out without a little help, So what do you guys use? /forums/images/graemlins/1zhelp.gif
  2. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    drain whatevers in there, and fill it up with water and powder cascade dishwasher detergent. Run it for a few hours drain that and refill with new antifreeze.
  3. dyeager535
    26,980
    Used vinegar before, not sure that it works any better than anything else, but it did pull a lot of stuff out.
    Radiator was still garbage, don't think any of the stuff you can buy will remove all the scale from the cores, and you can't see about 50% of the cores, so even if the top looks good, the bottom is probably not in as good a shape.
