Flushing radiator question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by James, Aug 4, 2000.
  1. James
    James 1/2 ton status
    Jun 22, 2000
    179
    Castaic, Ca
    Can someone tell me what the heck I'm doin wrong? This quest does not pertain to my 73k5 but I just bought a 91 camaro 305. Flushing the radiator by running engine and disconnecting outflow tube from thermostat to top of radiator. Atleast my book says this tube flow from thermostat to radiator and thru radiator back thru lower tube to engine block. Once I'm done flushing and water is clear. Add coolant and turns right back to milky white color. No green whatsoever. Can't imagine oil in water? hope not. Oil pressure gage is 0 from left 30 in middle and 60 all the way to right. Oil pressure gage never goes below 30 and fluctuates depending on how much gas applied while driving.Compression checks good in all cylinders. Anyone who has 305ci. Appreciate any info.
    James
  2. talldogg
    talldogg 1/2 ton status
    Jul 26, 2000
    754
    San Diego, CA
    Here's my guess, it sounds like you're not getting all of the old coolant out of the engine block. I did a partial flush on my dad's '97 LT1 and the book states that to do a COMPLETE flush you need to remove at least one of the plugs that are on the sides of the engine block, and let the fluid drip out. I don't remember if this is needed in flushing an older block, but it's still possible that there's not enough pressure to wash out the old coolant trapped in the block, good luck.
  3. Mr Red
    Mr Red 1/2 ton status
    263
    Washington, DC Metro Area
    Sounds like oil in coolant. If you go to a shop w/ a gas analyzer used for emissions testing, let the sniffer get a whif of the antifreeze mixture @ the radiator neck. If it detects hydrocarbons, you're finished (probably a head gasket or worse, cracked block...).
    When flushing my 305, I pulled the freeze plug (driver's side of block) and got a lot of junk out of the block (rust, corrosion, etc). That's your best bet when doing a good flush.
    Good Luck,
    <font color=red>David, '86 K5</font color=red>
  4. BlueOx
    BlueOx 1/2 ton status
    Aug 6, 2000
    239
    Houston, Tx
    If I were to try this flush on my 350 and I did pull the freeze plugs; how do I get them out. After I get them out how would i get them back in?
  5. James
    Jun 22, 2000
    179
    Castaic, Ca
    On the 350 its a bolt just above the oil pan on the drain plug side. I think. Can't miss it
