Flux Core Guys...
Discussion in 'The Tool Shed' started by mikey_d05, Aug 21, 2006.
  1. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I'm using a Miller 175 and .030 flux core at the moment. I usually reference the "recommended" settings to get me in the ballpark on stuff other than 1/4" plate.
    I'm finding that the suggested settings usually have 10%-20% more wire speed than I'd like and are a notch to two notches cold for amperage. Am I doing something wrong and need to change my style or is this fairly standard for the "ballpark" charts?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Fairly standard. Remember, day/night time weather conditions have a lot to do with it too.
  3. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,131
    27
    El Paso, TEXAS
    i just go with what feels right. i use the recommended stuff as just that.
  4. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Crank it up and don't worry about the "recommended" settings. I usually run a test bead using the recommended settings and end up turning it up some. I have a Lincoln 175.
  5. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,496
    1,206
    So Cal.
    I agree, crank it up and run it, but I would do a practice test weld on something and fine tune it from there. I like to weld good and hot so I get good penetration. would rather be on the hot side then the cold side for welding. a cold weld is a weld that can and or will fail.
