Fly wheel?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TOOLMAN125, Feb 27, 2003.
  1. TOOLMAN125
    TOOLMAN125 Registered Member
    Oct 7, 2002
    5
    Encino, CA
    I am looking to get rid of my th350/203 in my 77 chevy k10 and swich to a manual sm465/205. i need a flywheel but they want to know if my engine a 305 is internaly balanced or externaly balanced how can i tell the difference.
  2. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    The only small block that was externally balanced was the 400. The 305 and 350 are both internally balanced.
    Rene
  3. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    That was a true statement before 1986 when GM went to the one piece rear main seal and made all SBC's external balanced but only on the rear. Given the fact that he is working on a 79 you are correct unless someone swapped in a 1986 or later engine. /forums/images/graemlins/crazy.gif
  4. BigBen
    BigBen 1/2 ton status Premium Member
    Nov 14, 2002
    1,194
    Grand Haven, MI
    Yup, 350 pre 1-piece seal was internal balanced.
    I just had to swapt Flywheels on my 383.... it needed the external counterbalance parts (400 SBC crank). Don't ask how I found out /forums/images/graemlins/blush.gif, but it shook like a B!tch before I changed it this weekend.
    If you need a good condition used 168 tooth flywheel for a 350 PM me. I also have the zero balance damper/timing tab (almost new) that I had to change out.
    -Ben
  5. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    You wouldn't get far with the wrong flywheel... the 1-piece seal flywheel has a smaller bolt pattern on the crank than the 2-piece.
  6. BigBen
    Nov 14, 2002
    1,194
    Grand Haven, MI
    Good Point! /forums/images/graemlins/thumb.gif
