flywheel applications
Discussion in 'The Garage' started by bear76, Jan 25, 2007.
  1. bear76
    bear76 1/2 ton status
    Oct 16, 2005
    1,065
    here
    I've been looking for a flywheel for my 6.2. On summit they have a few listed and they are the same ones listed for the 350 of the same era (83'). Are they the same? If they are it might be alot easier to find one.
  2. Ronnie4wd
    Ronnie4wd 1/2 ton status GMOTM Winner
    Jun 4, 2002
    749
    Stockholm.Sweden
    No they are not the same someone else will tell you more but I think there is something about balancing the engine;)
  3. jdemaris
    jdemaris Registered Member
    Apr 10, 2001
    76
    6.2 diesel flywheels
    The Summint listing is incorrect. The 6.2 manual uses two different manual flywheels. If automatic, it uses two different flexplates - one for the TH400 and the other for the 700R4. With any of them, the tooth count is 139 which is not used on any of the gas engines. Most Chevy gasers use 168 teeth. 6.2 uses a 12" clutch.
    Most common manual-trans. flywheel is: DIESEL CASTING # 14050525 weighs 45 lbs. GM part # is 14077160.
    LUK 6.2 manual flywheel is a LFW-201 and fits all 6.2s 1982 - 1993.
    Perfection Clutch sells the manual flywheels new - i.e. no core-charge or trade-in needed. I think Autozone has them. Their part # is 50-2710.
    TH400 automatic flexplate is GM # 14077157
    700R4 automatic flexplate is GM # 14077158
  4. bear76
    Oct 16, 2005
    1,065
    here
    I have the a th400 behind it right now. Will I be able to use the same starter?
  5. bear76
    Oct 16, 2005
    1,065
    here
  6. Ronnie4wd
    Jun 4, 2002
    749
    Stockholm.Sweden
    I use the same starter.
