flywheel bent?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, Mar 29, 2002.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Sometimes at high speeds, or acceleration...basically higher RPM's, there is a really wierd sound coming from my engine area...sounds like a vibration of some sort...also, my starter sometimes makes that nasty grinding sound when I try to start it...could these be caused by a bent or out of balance flywheel? My flywheel is under warranty from my tranny rebuild, so it'll be free to replace if its bad, just wanted to know.
  2. calcide
    calcide 1/2 ton status
    Dec 21, 2001
    283
    You can pull off the dust cover and take a look at it. I had a cracked flexplate once, the engine made an RPM related ticking noise that went away while the engine was under load. After a while, the input seal to the transmission started leaking from the torque converter moving around.
    BTW, automatics have flexplates. Flywheels are for manual trans.
  3. René
    René 1/2 ton status
    Mar 14, 2002
    208
    Michelbach, Germany
    Could be
  4. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    I haven't heard of a bent flywheel or flexplate, but I've heard if cracked ones. If it's cracked it will stick under engine load.
