Flywheel casting number help
Discussion in 'The Garage' started by 79Jimmy, Jul 13, 2004.
  1. 79Jimmy
    79Jimmy 1/2 ton status
    May 10, 2000
    214
    Richmond BC, Canada
    I recently aquired this flywheel in the hopes it was for a 400 to be used in the 383 I'm building. The casting number is 3973457N GM2 113V . I've searched the net to the best of my ability but no luck /forums/images/graemlins/dunno.gif so I thought I'd utilize the bottomless knowlege and resources of CK5 /forums/images/graemlins/1zhelp.gif
    James
  2. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    If its a 400 smallblock one it will have a counterweight cast into it(manual tranny flywheel)or a balance weight welded to it if its an automatic flexplate--I'll try looking that number up for you and post back later--I have a dealers parts counter book that covers up to 1972,I'll see if it shows up in there...
  3. 79Jimmy
    May 10, 2000
    214
    Richmond BC, Canada
    Thanks. It does have a counterweight cast into the back oposite the casting number, it's just over 14" across the ring gear, about 13.5 across the face and its a 6 x 3.5" crank bolt pattern. I just for the life of me cant reference this casting number anywhere! Could it be aftermarket even with the "GM2" cast into it?
  4. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    I looked at all my books,no number that matches that one you listed--I stopped at the local junkyard and looked in their hollander interchange book--only number close to yours is 3973452 --thats a manual tranny flywheel for all the other small blocks except the 400,with a 10-1/2 inch clutch-.I assume we are talking a manual flywheel--I have one from a 72 350,it has two small "bumps" on the motor side that could be easily mistaken for counterweights,if you look at the back of the flywheel the bumps will be at the 4 o clock and 8 o clock positions if you hold the wheel with the bumps toward the bottom of the wheel--I'd make absolutely sure its the right one before you install it,since the wrong one will make it shake itself to death!.
    Does a 383 motor need the externally balanced 400 flywheel,or is it rebalanced internally??(not that familiar with that build up-- /forums/images/graemlins/dunno.gif)I bought a 3+3 crew cab truck for 300 bucks a long time ago that was sitting at a gas station for months,the owner refused to pay the mechanic for installing another motor because he claimed it was "junk" a because it vibrated real bad--turned out the guy put a 400 smallblock in it,and thought it was a 350,and used the flexplate from the 350--I saw the problem right away when I noticed the harmonic balancer was counterweighted,and the flex plate was not(no inspection cover!)--I played dumb while I bought it--got a good truck cheep! /forums/images/graemlins/grin.gif
