flywheel grinding on starter housing
Discussion in 'The Garage' started by down4thakrown, Jun 27, 2005.
  1. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    my flywheel is grinding on my starter housing. could this be a problem. i think its from my torque converter not bein set right the first time
  2. LongIslander26
    LongIslander26 1/2 ton status
    Jun 25, 2005
    256
    Park County, Montana
    Flywheel
    It sounds to me like your flexplate is installed backwards. The humps in the flexplate where the holes for the TC are need to be facing the tranny, not the engine.
  3. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    its on the right way then, i think its bent back alittle
  4. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    the side of it rubing the housing, could this cause damage to the engine?should i reaplace it or leave it :confused:
  5. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    If its wobbling, from a bent (cracked) flexplate, it will wear out the input bushing on your transmission and cause you problems there. Fix it. :crazy:
  6. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    i can see its bent with out spinnin the motor, its from the t/c not bein set right then the tranny tightend to the motor.
