Flywheel needed...
Discussion in 'Pacific Region' started by Poohbair, Mar 29, 2005.
  1. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I need a flywheel for a TBI 350... I think that those are the 1 piece rear main ones...
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    I've got a friends 12" clutch set and flywheel on my trailer for this weekends swap meet. Just not sure if it is for a 2 piece or 1 piece rear main. I'll call and see if he knows when he gets home from work and get back to you. He was only asking $35 for it all.
  3. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I am not sure how to tell the difference between the 1 and 2 piece rear main flywheels... does anyone else know?
  4. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    The one piece rear main crank has a smaller 6-bolt pattern on the back where the flywheel bolts on. Essentially, just a smaller in diameter bolt pattern than the older 2-piece flywheels.
  5. mountainexplorer
    Nov 14, 2001
    4,903
    Actually, I was just thinking about it more, and I have a friend that pulled the '91 Corvette 350 out of his yellow Suburban, and is putting the motor in a car with a TH350. So, he should have the manual flywheel that will work for you.
  6. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    sweet... wanna check and see if he wants to get rid of it?
  7. kennyw
    Jun 9, 2002
    13,224
    94
    Rick, for some reason I think your thinking about flexplates?
  8. 4xrick
    4xrick 1/2 ton status
    Sep 14, 2003
    1,102
    kirkland Wa
    ya i was. im a little too tired and not thinking straight. but whats new?
  9. kennyw
    Jun 9, 2002
    13,224
    94
    The flywheel I have is for a 2 piece rear main...
  10. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    2 piece RMS flywheel/flexplates have a 3.48" bolt circle, the 1 piece RMS flywheel/flexplates have a 3" bolt circle.
  11. paulmoon
    paulmoon 1/2 ton status
    Feb 11, 2004
    211
    Reno, NV
    OK... so are we looking for a flywheel or flexplate? I have a flywheel off my new crate engine. Newer style (one piece?). That what you need?
  12. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    yes flywheel for a manual tranny....for 1 piece rear main seal
  13. paulmoon
    Feb 11, 2004
    211
    Reno, NV
    OK, I checked the bolt pattern distance on my flywheel. It measures 3" center to center. The large hole in the middle is 2.050". It came off my Ramjet 350 engine. Which I believe is the one piece flywheel. I've attached pics. If this is what you need let me know. moonfam@usamedia.tv
    It weighs 28 lbs. Don't know how much to ship from Truckee, Ca. to you. I'll let it go cheap to offset shipping. Paul
  14. mountainexplorer
    Nov 14, 2001
    4,903
    My friend Nathan has the one off his '91 350. Finally asked him today. $35 OBO.
  15. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
  16. Goodwrencher
    Goodwrencher Registered Member
    Jul 9, 2005
    41
    Burlington, Wa.
    Flywheel?
    Manual or automatic? I have a great source for lightweight manual flywheels, both 168 tooth, and 153 tooth. 2-piece or 1 piece main seal.
