Flywheel question...gen V 454/6.2 diesel
Discussion in 'The Garage' started by Zeus33rd, Mar 6, 2006.
  1. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Will a 6.2 flywheel fit on the back of a Gen V 454? :confused:
  2. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    I dont think so...
    If I remember correctly,NO other motor shares the 6.2 crank bolt pattern..its a "loner",just like a caddy..no other GM motor uses the same bolt pattern on either of them,to my knowledge..
    I think I read in the diesel forum on another post that some years of 6.2's flywheels wont fit other years ,the crank bolt pattern is different,they changed it somewhere along the line..however,I'm not saying this is gospel,I could be wrong!..at any rate,a 454 will need a 454 flywheel,unless its a newer one past 1986,I know zilch about the newer stuff..they might not be externally balanced like the old ones were anymore..:confused: ..someone here will know..:crazy:
  3. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    The flywheel on the 454 depends if it is a 2piece rear main or a onepiece...summit has Hays flywheels fer around 230 or so..that is what I ended up getting...
  5. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I think I have a flywheel for a 454, I will check tonight if your interested
  6. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Just got the casting # from the block-
    14015445...454.......78-90...2 or 4 bolt
    Which means its a Gen IV 2 piece rear main seal block, and not the '90 and up 1 piece that needs a different flywheel. Jesse made a call for me today and can get a remanufactured /resurfaced flywheel for $140....but that includes a $90 core..:eek1: Guess they really want a core back! Anyways, thanks for the replies!:wink1:
  7. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    so buy the one for the 454 and then the next day go back and give them the flywheel for the 6.2. unless its a place you guys do business. do need to give jeese a bad name/ rep with a supplier. But if its a place like auto zone theyll never know thie differance:rolleyes:
  8. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Hmmmm.....:bow:
  9. 79k20350
    Nov 22, 2004
    7,757
    Ct
    i said differant day cause if they happen to have both sitting there in front of them they may notice the differance...but theres also a fee for these ideas...i thinks its about 89.95:D
