Flywheel question WTF??
Discussion in 'The Garage' started by CaveBlazin, Mar 1, 2004.
  1. CaveBlazin
    CaveBlazin 1/2 ton status Premium Member
    May 21, 2002
    1,348
    Middle TN
    Ok I hear that its possible to balance a 350 flywheel instead of using a 400 flywheel when building a 383 whats the dealie O.....
  2. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I'm sure it could be done. All that is needed is a weight welded to the flexplate/flywheel to achieve the balance.
    In my case, my machine shop welded a weight to the flywheel mounting flange of the crankshaft to achieve balance. That way I can run any internal balance flywheel I need. This was also useful if I switch to a manual tranny, no rebalance of the motor will be necessary. /forums/images/graemlins/waytogo.gif
  3. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    Hmmm I might have to check into this cause that would save me LOTS of money. Anyone else done this to there 350 when they built there 383??
