flywheel Question
Discussion in 'The Garage' started by atho, Mar 31, 2006.
  1. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    hey guys,
    quick question...can I use the flywheel that was originally behind a 427 tall deck truck motor behind a small block?
    thanks
  2. BadBob
    BadBob 1/2 ton status
    Aug 14, 2005
    158
    Lyndon, KS
    You should be able to, unless it's a 1 piece rear main seal small block. This is assuming that the 427T is neutral balanced like the 427 passenger engine.
  3. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    that is what i was wondering. i know the 454 has an odd balance, and flywheels for them will not work with smallblocks. but i don't really know jack about tall deck motors.
    thanks for the response Bob!
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Yes, it will work, the only BBC engine that was ever externally balanced is the 454. Like was said though, as long as the SBC isn't a 1 piece rear main engine it will work.
  5. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    sweet, thanks for the reply!
