Flywheel size
Discussion in 'The Garage' started by clarkjw24, Dec 20, 2004.
  1. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    What size flywheel comes on a 85 4x4 dually with the sm465/205? I guess I'm going to order a zoom or centerforce clutch and pressure plate setup. They list several different splines and diams. 10.4,11,12 and 26spline and 10spline. Also is there a difference in the diesel flywheel and the gas engine flywheel or are they the same?
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    ive only seen a 11" and a 12" clutch in trucks, both use the same flywheel.
    IIRC the sm465 is a 10 spline input.
    the flywheels are differnent between the gas and diesel, not sure how exactly.
