FLywheel toothcount
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TXsizeK5, Mar 4, 2002.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Im gunna buy a new pwrmaster starter, i dont know if i have 168 or 154 teeth on my flywheel, anyway to know? 87 with sm465 and 305. Mine is one of those v10 blazers that made in later yrs of 87 if that helps any, thanks.
  2. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    My truck was originally an 87 Custom Deluxe 305 SM465/208 setup and had the 168 tooth flywheel, 154 is mostly for cars I believe.
  3. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Slap a tape measure on the flywheel......the 168 tooth measures about 14" in diameter and the 153 tooth about 12".
  4. calvin
    calvin 1/2 ton status
    Oct 23, 2000
    152
    Brownstown, Michigan
    The starter for the 168 will work on the 153 also.
  5. Lonnie
    Lonnie 1/2 ton status
    Dec 5, 2001
    138
    Pittsburgh, PA
    Not all starters interchange......Stock units have different nosecones & some aftermarket units have a dual pattern.
    Lonnie
  6. calvin
    Oct 23, 2000
    152
    True, but I beleive the starter he's inquiring about is the one without the nose and dual bolt patterns. Am I correct?
    If not, sorry for the assumption
