Flywheel?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rockjunkies, May 22, 2002.
  1. Rockjunkies
    Rockjunkies 1/2 ton status
    Jul 26, 2001
    385
    Oklahoma
    Is the flywheel the same for T350 and700R4?
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    not sure. dont see how it could be different. maybe tooth count. but then it is a starter thing. diameter should be the same.
    what i need to know is if i can sandblast my flywheel....
    grant
  3. Rockjunkies
    Jul 26, 2001
    385
    Oklahoma
    My concern is the distance between the flywheel and torque converter. It looks like the converter will be pulled 3/8" away from it's fully seated position. It looks about right, just making sure that it won't pull it out to far.
  4. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    That's a flexplate not a flywhel. Standard trans use a flywheel. Autos use a flexplate
  5. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Same...
    471598 is the GM part number. It fits 305-350 up to 1985. After that, 1 piece rr seal. I don't have the current number for that one.
    Jim
