Folks with a 241..possible clearance help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Kyle89K5, Jan 17, 2002.
  1. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    Ground clearance, as we all know, SUCKS with the 241 case. Because of this, I may have found a solution. How much interest would there be in clocking the case up a little bit to gain a little more clearance? I've got a lead on someone making rings to clock the case up a little. It would make you driveline all of about 1/2" longer, but would gain some clearance underneath.
    Please let me know if anyone is interested as I will more than likely be looking into this for myself as well.
    Kyle
    89K5
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Take a close look at the internals of the 241 first. IIRC, the 241 has an internal pump that keeps it lubricated. I've never looked closely at how it works, but I'd think that you want to make sure that the pump can pickup oil after the case is clocked.
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    the clock ring also reduces shaft engagement
    formerly 77chev
    still a jerk though
  4. Kyle89K5
    2,273
    OKLAHOMA
    The ring would only clock it a couple of degrees. Not much. Oiling wouldn't be all that much of an issue. If I was clocking it 15 degrees, then I would have a pretty bad problem. The company making these is pretty dang reputable and has done some fairly intensive testing.
    Kyle
    89K5
  5. Kyle89K5
    2,273
    OKLAHOMA
    Maybe a little on the front, but not enough to cause issues. We're talking about less than an inch of loss. Not bad. On top of that, I need a new front driveshaft anyways, why not get one a little longer.
    Kyle
    89K5
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    transmission output to TC input engagement, not DS
    formerly 77chev
    still a jerk though
  7. Kyle89K5
    2,273
    OKLAHOMA
    Okay, I'm with ya now. How much engaement are we talking about that the output shaft has? The degree ring is roughly 1/2" thick. IMO, not enough to make a difference, but I may be wrong. Please let me know if I am.
    Kyle
    89K5
  8. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    I think MJ's talking about the loss of engagement between the tranny and t-case. If the adapter is thicker than the stocker, then the splines won't engage as far. [​IMG]
  9. Kyle89K5
    2,273
    OKLAHOMA
    These are some very interesting points that I'll try and get cleared up. There are already some of these rings on the road, I'll get on the horn and see what I can dig up.
    Kyle
    89K5
  10. Kyle89K5
    2,273
    OKLAHOMA
    ALRIGHTY then. The ring is about 1/4" thick and is in effect a spacer, that clocks the case. It moves it about 3-5 degrees up, so oiling is not effected and due to the rather small thickness, engagement is not an issue. This is dirrect from the manufacture. These rings basically have not been released to the general public, but are being used quite a bit on their shop test rigs.
    Kyle
    89K5
  11. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I have seen rings like this for sale on the net somewhere
    formerly 77chev
    still a jerk though
  12. Emmettology 101
    May 9, 2000
    8,126
    FL
    How much cabbage are we talking?
    Mike
    Emmett says: "<font color=green>It ain't easy being Green!</font color=green>
    <a target="_blank" href=http://www.geocities.com/emmettology101>EMMETT</a>
  13. Kyle89K5
    2,273
    OKLAHOMA
    Rumor is about a $100. Don't know for certain. They will give me tech info all day long, but nothing for price that is real specific.
    It's kinda a tough call for me, frankly, I like the 241 case. It's held up well. BUT I don't wanna dump so much coin into it that it's no longer worth it. I'm already eyeing a SYE kit and new rear shaft for it. The only prb with that is that I want to use a Flange style CV off the back and getting the right peice off a dodge is kinda tough.
    I guess we'll see if I hear anything back.
    Kyle
    89K5
