for a gas to diesel conversion..
Discussion in '1982-Present GM Diesel' started by Paxx, Mar 2, 2003.
  1. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    All Over Western Canada
    Do I need a fuel tank from a diesel blazer or is there any other type of tank I could use? I'm just thinking that it might be kind of hard to find one around here.
  2. RockyRider13
    RockyRider13 1/2 ton status
    Jul 11, 2001
    102
    Kansas
    just have it flushed. you will probably need to get a different sender, not sure. Check lmc or somthing to make sure that they are different parts.
  3. tRustyK5
    Jul 23, 2000
    36,170
    1,376
    E-town baby!
    I left all my lines hooked up to my old tank. I sat a big jerry can under the front crossmember and with both the supply and return line not hooked up I applied air pressure a little at a time to the return line and basically blew all the gas out of the tank and into the jerry can. When i had nothing but air and bubbles coming out I poured a gallon or two of deisel into the tank and did the same thing (different jerry can though)
    It only takes a couple of psi to get the fuel to come out...you don't need to get carried away. I don't imagine the fuel tank was designed for high pressure.
    The sender works just fine and I had no fuel related troubles...
    Rene
  4. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    this is gonna sound like a really dumb question but what exactly is the sender? Is it the fuel pump? I'm starting to get confused because it seems like there is a lot of different fuel pumps on a diesel /forums/images/graemlins/crazy.gif
  5. tRustyK5
    Jul 23, 2000
    36,170
    1,376
    E-town baby!
    The sender is just a float for the fuel gauge that is in the tank. It doesn't care what type of fuel is in there. The only diff as far as senders goes is some diesel tanks had a water in fuel detector and a drain somewhere near the tank in case you got water in the tank.
    The other pumps are the mechanical "Lift pump" (looks and works just like a mechanical fuel pump on a small block) and the injection pump which is on top of the 6.2 and has all the individual fuel lines attached to it.
    It makes more and more sense as you work on it and become familiar with what is what. When you get a chance pick up the Haynes diesel manual. I spent countless hours reading it and getting great general info from it.
    I'm still a diesel noob, but I can identify all the parts on sight now/forums/images/graemlins/thumb.gif
    Rene
  6. 4x4_76
    4x4_76 1/2 ton status
    Jul 22, 2001
    628
    Ylämaa, Finland
    I did gas to diesel swap about a year ago.I used gassers tank and sending unit.Works just fine.Only mod I did couple of months ago was to add rubber hose on sending units return line.I had little trouble when it was really cold and my fuel freezed in the tank.
