for anyone who has installed a 700r4/np205
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by xchevyxtc, Mar 4, 2003.
  1. xchevyxtc
    xchevyxtc Registered Member
    May 15, 2001
    33
    Southern California
    i am having trouble with my newly installed 700r4, the front driveshaft will not work, it hits the pan and will not fit...anyone done this and have some advice for me, i am running a 700r4 with the advance adapters shaft, np205 case and a tci aluminum pan that is an extra 2 quarts deep, (maybe thats the problem) thanks in advance for any pointers..
  2. 1Blazin71
    1Blazin71 1/2 ton status
    Aug 23, 2000
    112
    Los Angeles
    I had to cut about 2" out of the pass rear corner and a bit down the pass side of my deep alum pan to get it to clear the ds. Patched it back with alum plate and a friend with a TIG. Even a stock sized pan had only 1/8" clearance between the ear of the CV and the pan corner.
  3. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    My 700 pan is as descibed above,only about 1/8th to 1/4" of room between the front drive shaft and the stock 700 pan.I need to drop the front shaft to change the filter on the tranny.I can't access the bolt in that corner if I don't.
  4. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    I have the stock pan and it was gently clearanced to give 1/4 to 1/2" around the front shaft.
