for dollars spent
Discussion in 'The Garage' started by blazin_blazer, Nov 21, 2006.
  1. blazin_blazer
    blazin_blazer 1/2 ton status
    Aug 2, 2005
    4,043
    central arkansas
    how come the 2.5 ton rockwells are cheaper than the d60 or the 14 bolt? i play mostly in the mud and want to run the strongest axle i can swing under my rig, and upon searching i found the rockwells cheaper than the regular axles. this seemed odd because i've seen some rock crawlers with the rockwells also. as soon as the 54'' boggers are available i plan on running them but in the mean time i will run the 53'' goodyear gp-2b's. i have these tire already they runn them on the front of the fertilizer trucks around here, with like a 84" on the rear:dunno: would i be better off saving up more money and going with the d60f and a 14bff or run the rockwells? i plan on using custom springs also but that another different story. any info on the axle will be appreciated.
  2. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    I would imagine the Rockwells are cheaper due to weight and fabrication issues
  3. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    and the fact they arent that much stronger... sled and truck pulls are plenty popular here, and ive seen plenty of trucks go from one ton at one pull, to 2.5s at the next, and break the 2.5s easier... the shafts are nominally stronger and you can only have ONE ratio iirc... a d60 with 35s and ctms is plenty strong, and LIGHTER
  4. k5floyd
    k5floyd 1/2 ton status
    Feb 6, 2004
    313
    Friendswood, Tx
    just out of curiosity how much stronger is a beefed rocky than a beefed d60
  5. grimjaw
    grimjaw 1/2 ton status
    Jun 19, 2004
    944
    Seymour, TN
    A 'beefed' rockwell with 2" axles is Stupid strong....and stupid expensive.
  6. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    And stupid heavy, and not all that easy to properly mount.
  7. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    The reason they are cheaper is simple supply vs. demand. A 60 will bolt in real easy. a rockwell will require some fabrication. Brakes, steering, spring mounts, wheels all need to be addressed.
  8. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    in otherwords gents... go one ton chevy, you can find it, buy it and run it...
  9. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    yeah the axles themselves are cheaper. there is simply a lot more work to get them under a truck. especially if you want the truck "street legal"
