? for guys with 4" lift and 33" tires
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SlyDog, Jun 4, 2001.
  1. SlyDog
    SlyDog 1/2 ton status
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    Hey I'm lookin for a K5 as most of you know and our development is really gay and Im not allowed to work on my vehichle in the driveway! ! It has to be in the garage which is "ok" i guess since we have a 4 car garage but I was wonderin what the total height is for a K5 with 4" lift and 33" tires ? ? My garage door is 79" high so hope that works ! Or else ill have to trim the garage door with a Sawzall since I will be going higher . . . lol !
    Never Give Up Never Surrender
  2. MuleMaster
    MuleMaster 1/2 ton status
    Mar 2, 2000
    147
    Wayne, NJ 0747
    Re: ? for guys with 4\" lift and 33\" tires
    Uhhh, Slydog, that's going to be very tight. My Blazer (33", 4" suspension, 3" body) is remarkable higher than me, and I am 6'6".
    But even with the 3" body lift deducted chances are that after Your lift you will really have to use the Sawzall to get Your truck out of the garage ...
    All the best for Your work
    CU
    MuleMaster
    <font color=blue>K5 Blazer...because size DOES matter
    <A target="_blank" HREF=http://projectmule.coloradok5.com>http://projectmule.coloradok5.com</A></font color=blue>
  3. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I know it would be a pain in the a$$ but you could keep a set of cheap wheels and some realy short tires to throw on it so you could drive it in the garage.Just the wheels with no tires works too but it makes stripes on your driveway.
    All work and no beer makes Frizz a dull boy
  4. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    I think I would move. What the hell else is a drive way for??? Either move or cut your garage. LOL!!! [​IMG]
    <font color=red>I'm a psychic amnesiac. I know in advance what I'm going to forget. </font color=red>
  5. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    I have the same size garage door and lift and tires,you should have about 1 inch clearance.
    Steve Fox for President, 2004.
    Jimi Hendrix was re-incarnated in 1990 as my....JIMI
  6. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    keep a compressor handy, when you want to drive it in let the air out of the tires. Once out inflate them.
    ARQ.
    1-72 4x4 CST Blazer
    2-71 4x4 CST Blazer
  7. SlyDog
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    Thanks everyone ! Sounds like a tight squeeze but I will probaly find a way !
  8. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Ditto on the last. Thats what I thought I was going to have to do.
  9. sluggo45acp
    sluggo45acp 1/2 ton status
    Jan 2, 2001
    472
    Northern fortress, Republic of Texas
    Just measured my 75 with 4" lift and 33's, to the top of the factory roll bar 80" or 6'8" with the hard top on proubly 3 to 4 inch higher
    [​IMG]IF EVERYTHING WORKS IT AINT A REAL TRUCK[​IMG]
    Happy Wheelin[​IMG]
    Butch
  10. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I have a 3" lift and 33"s and it fits with a little room. Don't know how high the garage is, but when its on automatic its fine. When the door is on manual (the motor is broken right now) it rubs the roof. Luckily i have the top off, so i can reach out the window and push the door up. Screw the development, work on it in your driveway...if they say you can't work on it in your driveway, what about the street? Or the front yard? Or your neighbor's front yard? j/k
    90K5
  11. sluggo45acp
    Jan 2, 2001
    472
    Just check the hard top it adds 1" to overall for a total of 81"
    Happy Wheelin[​IMG]
    Butch
  12. delta9blazer
    delta9blazer 1/2 ton status
    1,646
    Northern California, over by 7-11
    my '89 has 4" and 35's, my total height is 6'9".
    wow. that's a lot of numbers in one sentence.
    <font color=purple>delta9blazer</font color=purple>
  13. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    My 85 with 4" and 33's measures 6' 9.5" (81.5") from the ground to the top of the cab.
    I'm so poor I can't even pay attention [​IMG]
  14. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    hey if all else that give you a reason to by an impact gun! and a floor jack if you don't have one! [​IMG] gotta make it as easy as possible huh? you'd even have the excuse for and air compressor if thats not in the shop! even if airing down would work... LOL [​IMG]
    [​IMG] <font color=blue> Jeff </font color=blue> [​IMG]
  15. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    My 86 is 6'9" also......Dan
  16. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    ..............which is why I built my shop with 8' doors.............if ya put a door at the back of yer garage, then ya can drive thru to the shop in the back yard......j/k....I'm thinkin' the fit is close enough....might have to let some air outta yer tires.....JD
    I'm at 10th and Plum....10 miles from nowhere, and Plum out in the sticks....Stuck?...Hell no..I still got some gas left..
  17. JunkYardCrawler
    JunkYardCrawler 1/2 ton status
    Sep 9, 2000
    575
    Tucson, AZ
    well i got a 4inch lift and 32's and my top can bearly fit in garage thats around 6ft8in
    Going nowhere everybody is a Moto Psycho
    Got my wheels in motion and i got a path to beat
