For my next stupid question...
Discussion in 'The Garage' started by babyburb, Feb 20, 2007.
  1. babyburb
    babyburb 1/2 ton status
    Oct 24, 2006
    2,344
    1H North of Dallas
    Tire shop told me I need to look at my Ujoints. I started checking and I believe I have a couple that need to be replaced. I have no idea what I am looking for so here is a couple of ???
    1. Just how many u-joints do I have?
    2 rear drive shaft
    2 front drive shaft
    2 on the D44 knuckles
    2. are they all the same size? I thought about carrying a couple extra but does one size fit all?
    3. I know the different sizes (1310, 1350, 1410, 1480) are thicker and stronger going up, but what size for the 3/4 ton burb.
    4.Spicer Life U-joint's? ($24, $24, $29, $54) Good Deal?
    Some advise for the newbie?
  2. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    i believe 6 is the total number for a k5. on front shaft, 2 on rear, and one for each axleshaft on the front. supposedly, all the driveshaft joints are the same. i've only replaced rear on the k5. i don't know about the joints on the axles, but i've heard they interchange, also.
    i know not everyone will agree with this method, but instead of dropping a ton of money on expensive joints, i grab the cheaper ones and get an extra for a trail spare, and come out way ahead, money-wise. but, mine is not a dd, and i don't wheel it as often as i'd like, so a cheaper joint will hold up longer than it would on a dd or truck that was wheeled every weekend (man, i'd love that). worked out well for me, so far.
  3. babyburb
    Oct 24, 2006
    2,344
    1H North of Dallas
    :bow: Thank you Vortec for the response.:bow:
    Might go cheap just because I am short on cash
  4. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,991
    130
    Your burb could have 1310, 1330, 1350, or S44 u-joints on the rear driveshaft. It will have either 1310 or S44 joints on the front shaft.
    The axle shafts have a whole different u-joint. I can't think of the number off the top of my head.
    Spicer u-joints aren't that expensive, in my experience, they are just as cheap as anything else. I paid about 1/2 what you posted, look around. You will probably be able to find them cheaper.
  5. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Joints are different. You probably have 2 different ones in your front dshaft. A tire shop probably only looked at you read driveshaft. If the joints are original, you will need a heat source to remove them.
  6. babyburb
    Oct 24, 2006
    2,344
    1H North of Dallas
    That's gunna be fun then, Babyburb with a heat source! :D :weld:
    Did I mention I almost caught Lake Texoma on fire this last weekend. What a trip that was.:doah: I guess I should post the story up in the lounge so everyone can make fun of me.
