? for people who have a doubler in there rig
Discussion in 'The Garage' started by BLZN4FN, Oct 30, 2004.
  1. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    So Im starting the phase 2 of the K5 and thinking of doing a doubler. Here are the questions
    How often do you use or need the doubler?
    what combo are you doing like th350 or th400 and why
    also that kind of wheeling do you do? rocks,mud ect...
    Anyone have any pics on how you did the crossmembers?
    I would also like any feed back on how it works or not what you thought it was going do for you.
    Thanks,
    BO
  2. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    Bo,
    I have had a Doubler in my truck for over 5 years. It has gone from a fullsize truck with 35's to my current S-Blazer with 42's. I have always done mostly rockcrawling, but rockcrawling back east usually involves mud at some point.
    I couldn't imagine what it was like to wheel with out it. I use it all of the time when wheeling for the extra gearing. Admittedly, I have found that at times, you really only need 1 low range, but that doesn't happen often.
    Transmission choice really depends on what you have now, or what else you might do with the truck. I originally used a TH400 because I did a lot of towing with my Blazer. With a Doubler, the transmission doesn't get strained as much due to the lower gearing. Put a good cooler on either a good 400 or 350, and it will live for a long time in front of a Doubler.
    Check out ORD's site for crossmember ideas, or 4x4 Iron. I have had just a single factory crossmember, which has worked, but not the best idea. Let me know if you have any more questions. /forums/images/graemlins/thumb.gif
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I have a 4 speed/205, no doubler, but I'm at approximately the same crawl ratio as a auto/doubler.
    If not for the cost I'd likely trade my hydro clutch 4 speed for a TH 400/doubler without thinking about it.
    Either way a good crawl ratio gives you awesome control--but I feel that with enough gearing, an automatic will give you more control over a 4 speed.
    There comes a point where it's too much--but I don't find that to ever be a problem at my current gearing and I believe it to be unlikely there would be any disadvantages to being 4:1 all the time (in fact if I could run a 5:1 Atlas I think that'd be great, too).
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I don't think there is such a thing as too low of a crawl ratio. The issue is when the ratio becomes so low and you don't have another option. Such as I think a combo of a SM465 and a 5.0 Atlas would be too low without more gearing options. Doubler has the option of a 2:1 or a 3.92:1(stop kidding its not 4:1)
    And tim whether you like to believe it or not torque convert slippage occurs so TH400-Doubler setups are lower crawl ratio than you.
  5. therobzilla
    therobzilla 1/2 ton status
    May 15, 2001
    1,307
    Gilbert, AZ
    Bo,
    I own a doubler and have had it in my rig for about 2 years. Don't know how I wheeled without it. We do quite a bit of crawlin, and you just can't wheel witout it here in AZ. It gives the drive the control that you need to deal with just about any situiation. Very nice to have all the gears you need when you need them. I won the Doubler at BB01, but stil had to do the other modification. It's not a cheap modification, with all that goes into it, but it was wort it as far as I am concerned.
    I'm still going to add the WMS 203 upgrade, I want more lower gears, I hope this year sometime. No such thing as too low of gears if you are crawling in the bigrocks.
    Good luck w/ your choice.
    Rob
  6. jac6695
    May 2, 2002
    1,860
    Christiansburg, VA
    I am not much of a manual transmission fan, but the SM465 and 5:1 Atlas has plenty of gear options. You would have 4 gearing options in low range, from the 6.54:1 first to the 1:1 fourth gear. Kinda hard to shift on the fly, though.
    Edit: I think being stuck with an auto and 5:1 low range would suck unless you have a manual valve body.
  7. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    sorry, whats this?
    WMS 203 upgrade
  8. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    sorry, whats this?
    WMS 203 upgrade
    http://www.wagonermachine.com/gear_set.htm
    it's a 3.1:1 gearset for the 203 range box.
    so you get 1.96, 3.1, and ~6.1 ratios (with a 205 in a doubler)
    /forums/images/graemlins/waytogo.gif
  9. GRAYTEXK5
    GRAYTEXK5 1/2 ton status
    Jul 23, 2002
    281
    Ft. Worth, TX
    does having a doubler have any negative effects in mud, other than maybe adding a little extra weight? or how bout on the street? and I read on ORD's site, that the doubler setup ends up being the same length as a 203...so is a second crossmember really necessary? is a second one needed, just because there's more weight, distributed farther back, or...?
  10. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    sorry, whats this?
    WMS 203 upgrade
    5.88:1 not 6. If the 205 has a 1.96:1 ratio(as it does) then 3 times 1.96:1 is 5.88:1. Sorry I know its stupid but a regular doubler isn't 4:1 its 3.92:1. Yeah so it only makes a slight difference when calculating crawl ratio its the truth.
  11. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    isn't the 203 a 2.01:1?
  12. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    2.01*1.96=3.9396
    3.1*1.96=6.076
    If you're going to be anal, at least be right.
  13. BLZN4FN
    Dec 19, 2000
    1,720
    Englewood Colorado
    Well hell I think im just going to do it. Thanks for all your input guys /forums/images/graemlins/thumb.gif
    what kinda of doubler does everyone have? WMS or ORD?
    which is better?
  14. jac6695
    May 2, 2002
    1,860
    Christiansburg, VA
    ORD all the way! The best customer service, a supporting vendor of CK5, and built here in Colorado. /forums/images/graemlins/thumb.gif
  15. CK5
    May 19, 1999
    21,624
    702
    CO
  16. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    sorry, whats this?
    WMS 203 upgrade
    So it gives me a lot higher crawl ratio... is that basically the same thing as the np205 3:1 kit that is being made right now, I remember an old post about it. or since ones in the front, and ones in the back of the doubler adaprter, is it different /forums/images/graemlins/confused.gif
  17. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Its the samething as the 205 3:1 kit, but its for a 203. Being in a doubler just means it "raises" the crawl ratio even more.
  18. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    okay I get it now. Thanks sleddy /forums/images/graemlins/bow.gif
  19. jac6695
    May 2, 2002
    1,860
    Christiansburg, VA
    Most people get away just fine with the stock gears in a 203/205 combo. Not a necessity.
  20. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I am getting one for mine and it is a DD (an AZ version of one)but I have no worrys.
    As for Rob and his 3:1 kit, he just likes to use his electric idle control for crawling. His rig is big budget. He doesn't even do his own tube work /forums/images/graemlins/grin.gif
    Actually Rob is one of the best sources I know of for this kind of thing. He is honest and knowledgable to boot. His rig is really a low budget rig other than TPI, the new chro-mo axles and an abundance of tools. He doesn't do his tube work cause he has friends that will trade it off for free. /forums/images/graemlins/pimp1.gif
