? for RS 9000 owners
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rubiconchevy, Nov 6, 2000.
  1. rubiconchevy
    rubiconchevy Registered Member
    Oct 29, 2000
    49
    Tracy,CA
    I just got my rancho 9000's the other day. part# rs9001 for the front and rs9112 for the rear. Question is the front shock tubing (valve body) is
    a little short compared to my skyjacker shocks. Which would limit travel,right? I called two of the local 4x shops and they all said it was the correct # for a 75 Blazer w/a 4" lift. Is that what everybody is running or is there a better option, besides 9012's with modified mounts. Thanks.
  2. k5king
    k5king 1/2 ton status
    Jul 23, 2000
    571
    Parkesburg, Pennsylvania
    hold your shocks side by side and extend both of them,,the shock body may be shorter but is the overall shock the same length
    ANYBODY LOSE THEIR JEEP????????[​IMG]
    I JUST FOUND ONE UNDER MY BLAZER!!!![​IMG]
    [​IMG][​IMG]
  3. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Do you have modified mounts? What is the length of your shock body on the original compared to the new ones? Fully extended are they both the same length?
    "Lord have mercy on my next thirty years"
  4. 1HIHUM
    1HIHUM 1/2 ton status
    Jun 28, 2000
    366
    Fremont, CA
    Is it possible the skyjackers were the wrong ones?
  5. tmf6902
    tmf6902 Newbie
    Nov 7, 2000
    I had the same problem, only with the rear shocks, when i put them on the shock was fully extended just sittin in the driveway. I just measured my old shocks and ordered the rs9000 that was the same length and everything works fine.
  6. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I belive that is the same setup I have too!! I will have to double check when I get home but I seam to recal 9001 being in the front!! Of corse I have a 72 but still running 4" in the front so??.....
    Hey I'm in Caif. too! near Modesto and my sister lives in Tahoe on the Calif side too!
    Later
    http://www.burt4x4.coloradok5.com
