For sale: 1-ton axles, Doubler, wheels and tires, etc.
Discussion in 'General Parts for Sale' started by Rockjunkies, Jul 7, 2003.
  1. Rockjunkies
    Rockjunkies 1/2 ton status
    Jul 26, 2001
    385
    Oklahoma
    I reserve the right to cancel the sale of the following items, but will only do so if no payments have been recieved. I prefer all items to be picked up, but can make other arrangements. My shipping zip code is 74008 if you need to know what shipping will cost. All items located in Bixby Ok.
    For sale: 1980 dana 60 front axle complete, 5.13 gears, detroit locker, ord crossover arm, remanufactured caliper's ground for 15" wheels, all new bearings and seals, fresh steering joints. Has broken short inner shaft wich I will replace before the sale, or will discount 150.00 to buyer. 14-bolt rear axle, 5.13 gears, welded, shaved bottom lip, disc brake conversion without emergency brake, 1410 rear yoke, compete. I will include two 16" stainless brake lines for the front, one 16 " brake line for the rear, all u-bolts and spring plates, and I will throw in a new set of rear spring perches for buyer to weld on. I also have a traction bar that I built for the rear axle that can be included. It is built similar to the one that Sams sells. It has two bushings at the rear and a shackle and Johny joint on the front. I also have the heavy duty tie rod ends for the steering arm. 2500.00
    Doubler made by WMS. This includes the complete setup, Turbo 350 trans, 203, 205. The trans needs rebuilt, the transfer cases are fine. The rear yoke needs to be replaced. The 203 is mounted upside down and the 205 is clocked 2" up. I will include the shifters that I made for my setup, may not work for yours. I will also include the crossmember wich can be modified to fit your needs. 1200.00
    A set of 4 39.5 swampers mounted on 15 x 10 MRT beadlocks. The tires have around 1000 actual street miles, but have been wheeled aprox. 10 times. So there is some cuts, chunks and other battle scares. They hold air and still have lots of tread left. The rims have only minor scrapes on the bead locks, powder coated black, I will have to measure the backspace, they are the ones needed for the front brakes to clear. 1400.00
    A set a four shocks, pro comp 15" travel. 100.00
    Two pair of ORD zero rates. 40.00
    ORD 73-87 shackle flip missing bolts. SOLD
    All above items are used but in good shape unless noted. Sold as is. All reasonable offers will be considered. All items excluding the shackle flip brackets, are mounted on my 89 Wrangler that I built last winter, they will be removed as needed. Pitcures can be available.
    I have considered selling the vehicle complete and will do so unless there is interst on all items, so feel free to throw me some offers.
  2. 84K5cedric
    84K5cedric 1/2 ton status
    Aug 2, 2002
    279
    Austin, TX 78660
    is this each or both sets for $40
    dibs on these.
  3. Rockin
    Rockin Registered Member
    Sep 15, 2002
    42
    Bend, OR
    Interested in the Doubler. Do you have any pics? I won't need the T350.
  4. Rockjunkies
    Jul 26, 2001
    385
    Oklahoma
    That is 40 for both. May need new centering pins, not a big deal though.
  5. Rockjunkies
    Jul 26, 2001
    385
    Oklahoma
    I will try to get pics tomorrow. But I can tell you that it just looks like two transfer cases mounted behind a transmision.
  6. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I call seconds -dibs /forums/images/graemlins/thumb.gif
  7. jackedjimmy350
    jackedjimmy350 1/2 ton status
    Oct 20, 2000
    3,141
    Fort Smith, Arkansas 72901
    dibs on the flip /forums/images/graemlins/thumb.gif
  8. Flexy K20
    Flexy K20 1/2 ton status
    Oct 22, 2002
    398
    Bay Area, CA
    Put me second in line for the flip.
    -fLeXy K20
  9. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Shoot me a pm with your address and a time I can come by and look at the doubler. btw, what would you want for the whole setup?
  10. Rockjunkies
    Jul 26, 2001
    385
    Oklahoma
    Shackle flip is now sold.
  11. Rockjunkies
    Jul 26, 2001
    385
    Oklahoma
    P.M.s will have priority over replies. I do not wish to sell the zero rates or shocks or any other small item until some of the bigger stuff is sold. I can't justify tearing my rig down just to sell something minor until axles or transfercases are sold. Thank you.
  12. 84K5cedric
    Aug 2, 2002
    279
    Austin, TX 78660
    ok, just let me know when you are ready to sell the zero rates... consider them sold.
    pm'd ya too just in case.
  13. Rockjunkies
    Jul 26, 2001
    385
    Oklahoma
    Dropped the price of the axles down to 2500.00 May have been to high to start with.
  14. fastboy_01
    fastboy_01 Registered Member
    Feb 12, 2003
    19
    Northern Michigan
    Would you be interested in selling just the D60?
  15. Highliner
    Highliner Registered Member
    Oct 20, 2001
    91
    Iowa Park, Texas
    Sent you a PM.
  16. Rockjunkies
    Jul 26, 2001
    385
    Oklahoma
    At this time I would prefer not to seperate the axles. But I will keep you in mind if I find a buyer for the rear axle as well.
  17. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    Sent you a PM
    Eric
