for the love of gawd, why me.
Discussion in 'Pacific Region' started by jekbrown, Mar 4, 2003.
  1. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    see my post on the garage forum.... something in my ff14b went "pop". opened the cover... gear tooth laying in the bottom of the diff. /forums/images/graemlins/frown.gif unless there is a miracle... there goes TSF this month... /forums/images/graemlins/frown.gif !!!!! /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/crazy.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif
    j
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    well that sucks /forums/images/graemlins/frown.gif
  3. UNCLE CRACKER
    UNCLE CRACKER 1/2 ton status
    Dec 29, 2001
    937
    PORTLAND OR
    man that sucks. who set up your ring and pinion? the guy (darrel) that did my truck and josh's ring and pinion did a awsome job sounds like its time to give him a call, unless you have a warranty from the other shop that did the install.
  4. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    'cause yer SO special!! /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif j/k couldn't resist man.
    Was it one of the spiders we welded up?? Or was it the ring gear?
  5. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Maybe it was a welded spider gear tooth. If it were a ring/pinion tooth the truck would be making lots of noise.
  6. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Better to have happened in the driveway if it is gonna happen.
    TSF is no place to have yer rig take a dump on ya.
    Unless ya brought it in on a Trailer.
    I remember when Shannons rear axle let go at Sand Lake, 12 bolt so no pulling out the shafts and motoring on. He did drive it home though. That was it for me, the next weekend I was rolling on 3/4 ton axles.
    I finaly got around to cracking open the cover when Rob was gonna get it.
    It was pretty ugly in there. But that was a 12 bolt axle as well.
    As for yours.. It sounds like the bearing preload was to tight.
    Who set up the gears?
    If it wasn't making any unusual noise when you drove it then chances are the bearings were to tight.
    Gears that are set up to tight are gonna whine like a 2 year old.
    Either the carrier bearings or the pinion bearings are gonna be cooked.
    If it got hot enough to smoke paint then it will be real obvious as to what went out.
    If it was the pinion bearings the gears are gonna be no good.
    If it was hot enough to smoke paint on the outside whatever went out would have been glowing. /forums/images/graemlins/eek.gif
    It does not take much over the specified setting to smoke bearings, they can and do get hot in a hurry.
    I have seen more than enough of them.
    Diff and wheel bearings.
  7. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Weren't you saying the rearend got really hot when you first drove it after the gear setup? Sounds like they did something wrong..........get with your installer and ask about your 'warranty'. Good luck......... /forums/images/graemlins/cool.gif
  8. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    I think he did them himself....if I remember correctly...
  9. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    sorta good news... the 14b is fixed... quick turn around over at woodys. Now... if i can get my tcase swapped in, i can still make it to TSF... hope against hope! /forums/images/graemlins/grin.gif we'll see... all i can do right now is hope. *crosses fingers*
    j
