For the people that run/ran 12 bolt with detroit - what part breaks?
Discussion in 'The Garage' started by bajaviking, Aug 27, 2004.
  1. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    For the people that have been running 12 bolts with a detroit Locker what did you break? The detroit, the axle shafts, ring/pinion, your neck? Other?
    Please save the 14 bolt FF comments for somebody else, I can get a detroit installed for cheap and I am not interested in the 14 bolt at this point.
  2. blueblaze
    blueblaze 1/2 ton status
    Dec 4, 2001
    274
    Salt Lake City, UT
    The only thing was 2 axle shafts..."knock on wood"... /forums/images/graemlins/grin.gif
  3. bajaviking
    Apr 10, 2002
    752
    Baja
    I actually have a complete extra 12 bolt differential so spares is not a problem. I am thinking that the Detroit is pretty strong so carrier breakage should not be a problem and I can deal with changing a shaft now and then /forums/images/graemlins/thinking.gif
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I have a couple friends with detroits and 35" tires. They wheel hard and what I have heard and seen are axleshafts and ring & pinions.
    I witnessed TheRobZilla pop a 12 bolt shaft in his K5. Pretty awesome sound when you hear it and all you see is sky as you are climbing a waterfall. /forums/images/graemlins/peace.gif
    A buddy of mine Robert has had a couple ring and pinions go in a K10 longbed that he rockcrawled pretty hard.
    Robs axleshafts had been in the axle for a long time taking a pretty heavy beating before they let go. He is light on the go pedal and has a controlled wheeling style too though. Get crazy with the skinny pedal and the breakage will be a toss up.
    Harley
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    When my 12 bolt failed it was open, but the pinion bearing exploded, destroying the ring and pinion, the housing, and the carrier.
    Just something to keep in mind.
  6. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    ive seen the pinion bearings fall apart, lucky we cought it soon enough that the ring and pinion were still good.
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I had a 14 bolt SF in the garage already so I didn't bother fixing it, I just waited for it to pop and came home and put it in.
    That was about 3 years ago.
