? for thoose who have tore down a np205
Discussion in 'The Garage' started by cegusman, Jan 29, 2003.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Is there anything I should know befor I tear apart my np205? I have rebuilt a np208 before and have tor down a sm465 but no 205. Any tricks/tips? /forums/images/graemlins/k5.gif /forums/images/graemlins/ears.gif
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    You have a PM.... /forums/images/graemlins/thumb.gif
  3. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    thanks
  4. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    that's not very nice... what about the rest of us that will be tearing into our 205s (next week)? /forums/images/graemlins/mad.gif
  5. chevyfumes
    Feb 24, 2000
    38,584
    266
    I didn't want any of the bluebies to get it, its in the bloody knuckle about the 7th page by leadfoot... /forums/images/graemlins/thumb.gif
  6. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    If you have specific questions you can PM me (I'm usually not online during the weekend). Since you have rebuilt the 208/465 you should have a good idea on how to rebuild the 205. The biggest thing is have an open work area, look at the orientation of the parts as you take them out (especially the shift forks, hi/low gears, and idler assy) and order and orientation of shims and thrust washers. The forks are interchangeable, but they are designed to fit one way (the front side is different than the back). A heavy duty set of snap ring plyers is a major time and band-aid saver. You will also need a dial indicator and ft/lbs torque wrench for the idler endplay adjustment.
    Take your time and you will be fine. I will PM you my cell number. If you have any questions give me a ring.
    Chris
  7. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Good point on the HD snap ring pliers ! I loaned a few of my "good" pliers out and had to go through a 205 with a lesser set of pliers and it was a finger beating experience at best ......
    One more note since you are re-doing the 205 , when you order the bearing kit - make sure that the radial ball bearings are the "maximum capacity" type and not the standard bearings. Some of the rebuild kits use the least exspensive bearings;also make sure that the seals are a double lip design .
    Good luck , Tom
  8. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Who would sell one of these better rebuild kits?
  9. trukman1
    trukman1 1/2 ton status
    Mar 5, 2002
    129
    Ohio
    Try www.4xheaven.com for parts and info...great people. Also, my old Factory Overhaul Manual seemed to indicate the roll pins in the shift fork/rails had to be taken out from the top...not so, just drive them straight thru with a punch and fish them out of the case later.
  10. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    The biggest PITA is putting the idler shaft back though the idler gears. I dont mean PITA, I mean FAWKING PITA-go and punch some one in the face PITA (yes thats how I really feel)
    Do this, when reinstalling the idler shaft use one of those black and decker workmate benches. You know the ones that open and close. Open it up 5-6" and put the case down on the back side so the larger shaft hole is visable through the open space. This way when you put the idler gear in the end with the shims in it are facing up and the bearing shouldnt flop around and casue the shims to get all out of alignment.
    Insert the shaft and start to tap it into place.
    Once it gets close to the shims use a pick and get the shims as close to being aligned as possable (they will get a little out of place when you wrestle getting the gears back in)
    Then SLOWLY start tapping the shaft. Once its tight with the shims use your pick and make sure ALL OF THE SHIMS ARE OUT OF THE WAY OF THE SHAFT!!! then slowly tap it the rest of the way through.
    I wrecked 15 shims until I used the workmate bench. Those replacement shims are not cheap and no GM dealership has them in stock (nor do any parts stores)
  11. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    I have seen different bearings from the same part # kit from several vendors . BCA offers a descent kit as do some of the ring & pinion parts houses. Just look for a maximum capacity radial ball bearings ( they use extra # of balls and have a insert groove on the inner race and the outer race ). More than likely you will need to go to an industrial parts supply house to get the "good" seals - all of the ones in the kits that I have seen have been the cheaper ones .
    HTH , Tom
