For thos doing disc brake swaps
Discussion in 'The Garage' started by wraenking, Feb 9, 2005.
  1. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    well, after a few days of trying to bleed my rear brakes with the caddy calipers, i just learned that you first have to have your e brake set before you can bleed them or as in my case you will always have a spongy pedal
    the fix:
    jack up the rear, and disconnect the ebrake lines. spin each wheel and ratchet the e brake lever (on the caliper) until you feel friction on the tire. reapeat for othe side, hook the e brake lines back up, and re bleed system.
    after a couple of days of fighting this, i was done in about ten minutes.
    dont get me wrong, at first it WILL take a while to bleed.
    thanks
  2. dyeager535
    26,979
    As I understand it, the calipers should "self adjust" tighter when you use the ebrake. Shouldn't be any need to disconnect the cables, but apparently you should start out by applying the e-brake until it gets tight, then bleed.
  3. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    might be so, so should work either way. i also heard that to adjust them, just hold out the e brake lever in the cab and pump the e brake.
  4. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I didnt need to do that on mine, only took about 45 seconds per wheel to get the air out, and I have a firm pedal, guess I just got lucky :D
  5. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    are you e brakes connected?
    if so, you might have gotten lucky that they were all the way out when you started.
  6. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    yea that prolly has somehting to do with it, my e-brake isnt hooked up,still need to find the levers and springs :mad:
