For those of you that have done the rear disc swap...
Discussion in 'The Garage' started by BlackDog714, Apr 5, 2004.
  1. BlackDog714
    BlackDog714 1/2 ton status
    Jun 8, 2002
    260
    Indiana
    Did you have to get longer studs? it appears that with the thickness of the hub and the hat on the rotor, that I am only going to have 5/8's to 3/4's of an inch stud to mount my wheels on... Do they make longer studs for the 14 BFF? Anyone have a part # and/or price?
  2. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    I didn't need longer studs, mine were perfect, they stick about 1/16" out of the lug nuts. I run steel wheels, with alluminum wheels I would have definately needed longer studs. Just go to your local Autozone/Napa/Whatever and bring a stud in with you. They will match up the threads, should be 9/16", and you cna pick out a length that you like.
  3. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    Mine were long enough.
  4. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    Or2play did his before i did mine. his studs stuck IN the lug nut about 1/16th of an inch. so before i decided to put mine together i went and got studs for a dually.
    they stick out as far as the hub does, but work fine for the stock rims.
    grant
  5. 87GMCJimmy
    87GMCJimmy 1/2 ton status
    Nov 21, 2001
    582
    Phoenix, AZ
    Nope, stock studs worked fine for me.
    Mike
  6. grd2go
    grd2go Registered Member
    Mar 28, 2004
    55
    Anchorage Ak
    We have stock one in both the ones we built but are running steel wheels.. /forums/images/graemlins/crewcab.gif/forums/images/graemlins/hack.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/weld.gif
  7. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    If your original drums were the 11" and not the 13" then you will probalby need new studs if you are using aluminum wheels. Just go to any parts store and ask for wheel studs for a 3/4 ton truck with 13" drums. /forums/images/graemlins/thumb.gif
    Also on some rotors the relieve for the head of the stud to sit in is not large enough for the stud to seat properly so you may need to trim the OD of the stud head smaller to fit properly. /forums/images/graemlins/thumb.gif
  8. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I had to do that for mine. It sucked cause at the time I didn't have acces to a lathe. So I did 16 of them by hand on a bench grinder. My fingers were pretty shot afterwards. /forums/images/graemlins/crazy.gif
  9. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Had to change mine.
  10. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I had to change mine. With steel wheels on, the stud only ended up going 1/2 way through nut. I put "dually" studs in. Plenty long now.
  11. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I'm running steel wheels on mine and I didn't have to change them
  12. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I'm running steel wheels and did not need to change the factory studs. /forums/images/graemlins/waytogo.gif
