for those of you that put 3" body lifts on ur rigs
Discussion in 'The Garage' started by bryguy00b, Oct 19, 2003.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    for those of you that put 3\" body lifts on ur rigs
    whats issues did you run into..fan shroud...tranny linkage...steering shaft..anything else? what did you do for these? mostly the steering shaft..
  2. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    Re: for those of you that put 3\" body lifts on ur rigs
    there was a post a while back with a large list of potenial issues. you may want to do a search in addition
    a couple to add to your list would be speedo cable and tcase linkage.
    fan shroud - i took a sawzall and cut the lower section of the hroud away until the fan cleaared
    steering shaft - i didnt touch it, it seems to work, there is an expansion/compression joint in there already to keep the steering wheel from impacting you when you hit something head-on
    t-case linkage - im not sure on a 208 (if that is what you ahve) if there is enough adjustment.
    tranny linkage - just cut and reweld a spacer rod in your current linkage.
    speedo cable - mine was a stretch, yours might work also.
    good luck
  3. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    thanx...tryed a search didnt come up with to much so i posted...i think ill just go for it and see what happens..also i was thinking about putting a floor shifter in instead of the column shifter so that would probobly iliminate that problem.but of course thats another 100 bucks or so..so that wouldnt happen till after the fact..easy enoug to just modify the linkage anyhow
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I left steering shaft alone too...no issues as of yet. Seems fine.
  5. conoverbandit
    conoverbandit 1/2 ton status
    Jan 23, 2002
    452
    Conover N.C
    Same here,
    Took and cut bottom of fan shroud, The steering shaft worked without problem, Cut tranny linkage and added 3in. T-case I just left it hooked to my 203, it's 3in. shorter then it was but still works fine,speedo, was a bit fun, but got a cable 3in.longer for a chevy truck,hooked right in my 203 case.(Too bad the speedo has'nt worked in this truck for a couple years!LOL) it did'nt work when my neghibor had it. But that's another thread.
  6. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    yea thats another idea..screw the speedo cable all together lol..but if i can make it work i would..were could you find a longer cable anyhow?
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Well in my case, I had an auto trans from the factory and now I have a manual so thats probably where the extra speedo cable came from. If not, swap in a cable from a longer tranny/xfer setup.
  8. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    W/ the 208 youll have issues w/ the Tcase linkage w/ the shifter mounted to the body. Not a real bright move on GMs part IMO. I had to make a "Zbar" type linkage for it. Its not perfect but it works 99% of the time. On particularly hard mud runs or hits on a snatch strap pulling someone itll pop out on me sometimes from the movement of the eng tranny and case.
    My speedo cable worked fine, the fan shroud was all butched up but I went to electric so it didnt matter, and the yahoo P/O welded all the bumper mounts on in the lifted position. /forums/images/graemlins/rolleyes.gif
    I did NOT install the B/L on mine but have been fixing the P/Os screw ups. /forums/images/graemlins/ignore.gif
