For those of you with an ORD crossover draglink...
Discussion in 'The Garage' started by K5thatShmobs, Mar 26, 2003.
  1. K5thatShmobs
    K5thatShmobs 1/2 ton status
    Sep 27, 2001
    353
    San Luis Obispo, CA
    What tie rod ends did you use? I would just get the ones that ORD sells, but $110.00 seems a little steep for two. I want to get them on my own to save a little money.
  2. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    I used the ones from ORD
  3. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    I think i also used ORD's. sorry cant help
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I used a Chevy one and a Dodge one. I cant remember the part numbers but I got them out of the "Post yer part numbers" listing in the Bloody Knuckle.
  5. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    It depends on whether or not you want to use TRE (Tie Rod Ends), or DLE (Drag Link Ends). The DLE's are beefier and have a greater range of motion, which is why I run those.
    DLE Part Numbers
    ES2027L
    ES2026R
    TRE Part Numbers
    ES2010L
    ES2234R
    I just bought a new set of the bigger DLE's at Autozone for ES2027L - 17.99 and ES2026R - 21.99
    The smaller TRE's are more expensive..
    ES2010L - 47.99 and ES2234R - 24.99
    Hope this helps...
  6. K5thatShmobs
    Sep 27, 2001
    353
    San Luis Obispo, CA
    What company are those TRE numbers for? Are these part numbers for the 7/8" or 1" threaded TREs?
  7. Waxer
    1,857
    Long Beach, CA.
    those are all 7/8, and they are McQuay Norris.
  8. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    aren't the ones supplied from
    ORD the ES2010L and ES2010R TREs???
  9. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    I used a stock Gm three peice t/r, shortened, and used stock GM DLEs. Numbers are posted elsewhere.
  10. K5thatShmobs
    Sep 27, 2001
    353
    San Luis Obispo, CA
    I called ORD today and they said they used spicer ends. (TREs)
