For those of you with Poly body mounts...
Discussion in 'The Garage' started by fortcollinsram, May 13, 2003.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    What did you use to lube up the poly mounts so they wouldn't squeak like a mofo...? I was thinking Syl-Glyde (the suff you use to lube float pins and such on disc brakes)I just hate theat damn squeaky noise they tend ot get...any ideas?
    Chris
  2. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    Astro Glide or KY /forums/images/graemlins/grin.gif
    Actually I used white lithium grease. Someone sugested graphite. Mine have been on for 6 months and don't squeak
  3. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Although you make fun of it Asto Glide is awesome for lubricating seals on the hard top to keep them from sticking over the winter months... /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
    Chris
  4. dyeager535
    26,979
    Body mounts aren't supposed to be moving, you might want to check into tightening them up.
    My truck was squeaking before and after the poly body mounts, I can't blame the mounts.
    My poly mounts made no difference over stock. No more noise, no more harshness in ride, nothing. No chance yet to check to see if they stiffened the body up enough to keep the body panels from flexing as much though.
  5. Grim-Reaper
    7,385
    Atlanta
    Only time I hear my pollys is when the truck is really twisted up off road. They don't squeek at all on the road. Now my polly suspension is a different story.
    After having polly body mounts I will NEVER put them on a daily driver. Trail truck...yeah I would do it again.
    So much road noise and engine noise is now transmittied it isn't even funny. My mounts were so bad that at a couple places the floor was touching the frame. Now there is a minimum of 1.5 inches with the adition of a 1 inch body lift. More noise then when the body was touching even.
  6. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    The poly mounts I got from Energy Supension were impregnegted with polygraphite(black ones not red) to reduce the dreaded poly squeak. I don't hear mine at all, they have been in there for about 8yrs maby more.
  7. bobsurf
    bobsurf 1/2 ton status
    Jun 26, 2001
    410
    San Marcos, CA
    Interesting. I know nothing about poly body mounts (or any style for that matter), but just assumed I'd get a set of polys from Energy suspension. The mounts for my core support are completely shot (read: torn up, hanging out). My truck will probably be my weekend driver/Trail truck. Would you recommend I go a different route than poly?
    Oh yeah, not planning on lifting the body at all.
  8. 76SILVERADO
    76SILVERADO Registered Member
    Mar 1, 2003
    52
    AZ
    i have the energy suspension ones.... no noise here
  9. Grim-Reaper
    7,385
    Atlanta
    Well my truck is bare steel floor. That is part of the problem. some carpet would absorb a lot of the noise. I'm getting ready to hurculine it. I'll see if it makes a difference. I plan to use a undercoating gun and spray the huculiner so I can get it a little thicker up front.
    The noise is not horrible but I noticed it the first 100 feet I drove it. I actually turned around and ulled back in the drive and spent some time making sure that there wasn't soemthing wrong. The noise is actually noise off both the engine and the tires resonating on the body.
    If you remeber Dean Waters and the blue 74 over a ORC he made comment about it as well when he went to Polly.
  10. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    same here, no lube on rubbers /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    yeah I know they are not rubber its a joke /forums/images/graemlins/deal.gif
    poly bushings
  11. mcmlxix
    mcmlxix Registered Member
    Nov 28, 2001
    80
    Las Vegas
    Do the energy suspension poly mounts give a harsh ride. I need to replace the stock mounts and not sure if I want to go poly or just with new rubber ones. LMC sells the stock kit with hardware. I also want a 2" body lift.
  12. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    I suspect you might have something else wrong Grimmy. I have poly body mounts all around on my 74 and have no problems with noise, squeaking, or anything. They don't transmit any more vibration than the stock rubbers did.
    Maybe I'm just lucky? I dunno...
    I used a poly set that I ordered from JC Whitney. They were daystars I think. It's been a good 3 years since I put these suckers in.
  13. Grim-Reaper
    7,385
    Atlanta
    I'm an old man...sensitive to noise. /forums/images/graemlins/rotfl.gif
    I can tell when my #5 plug is starting to foul.
  14. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    grim
    after the concert i went to last night it'd be good to here my truck running.
    could you put 1/4 inch or so hardened rubber mount or so to helpo stop the squeek. kind like a spring pad cut to size.
    nathan
