For those that have done the swap to 14b ff......
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Zeus33rd, Jun 12, 2002.
  1. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I finally got my hands on a 14b ff, and I'll be doin the swap this weekend I hope, Is there anything that I need to know? Anything thats gonna hold me up? I'm pretty sure I have all the basees covered, spring perches and all that are good....GOt the necisisary U-joint from napa....Anything else that might jump up and bite me in the butt? /forums/images/icons/confused.gif
  2. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    The '72 3/4 ton (eaton) in my blazer had a different size fittings for the brake lines at the axle than the 12 bolt I took out. I was able to get 2 bushings that adapted the line to the hardlines on the axle. /forums/images/icons/cool.gif
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Should bolt right in. You might have to get a conversion u-joint for the bigger yoke. decent auto store will have one.
  4. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Got u bolts? /forums/images/icons/grin.gif
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Got Spring Plates? /forums/images/icons/grin.gif
    Also did you get the 14B with the e-brake cables?
  6. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Shocks...? May be a good time to explore a long-travel setup.
    Also, driveshaft length....I think the 14BFF is about 5/8" longer than the 1/2 Ton stuff, so you might want to look at how much "spline" you've got now.
    I'm doing this swap now too.....got the 12-Bolt out last night and rolled the 14BFF under. Still a long way to go though (disc brakes, spring perches, locker, etc)
  7. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Also measure the spring perches first!! Dummy me didn't and discovered that a 1 ton 14 bolt FF is narrower by a couple of inches in spring perch measurement!! Went to install it and had to reinstall the one I removed!!!!
  8. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    But a 1 ton 14b ff works fine in a 1st gen. /forums/images/icons/cool.gif /forums/images/icons/cool.gif /forums/images/icons/cool.gif
  9. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    8 lug rims and tires...
  10. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I've got the u-joint. And I'm buds with the assitant manager at the Les Schwab tire place in town, he's hookin me up with the 15x10 8 luggers at a killer discount. The driveshaft issue is covered. I did forget about the u-bolts and spring plates thoug. No prob gettin them..Can get them free, but I'm glad ya'all reminded me here. /forums/images/icons/cool.gif It's out of a 3/4 ton so the spring perches are the same. And yes the 14 bolt came with the e-brake cables, so thats covered too. Hmm....Just picked up the 80-90, gasket and RTV today....Hrrmmm...What else? I think thats it. lol, I hope..... /forums/images/icons/grin.gif
  11. BlueOx
    BlueOx 1/2 ton status
    Aug 6, 2000
    239
    Houston, Tx
    I have been looking at doing the same thing but I have some questions. What are spring plates and do you need to get the whole e-brake cable. What are the backing plates for that they mention in the 14b swap article in the technical section?
  12. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    What rear flex brake line are you using? Check to be sure it fits the hardlines on the axle/ frame. I bought the procomp set. The fronts fit fine. The rear was for 1/4" hardline on the frame and that end fit. The axle end was for 3/16" and my axle had 1/4" hardlines so I got 2 adapters from 3/16" female flare to 1/4" male flare and made it work. /forums/images/icons/smile.gif /forums/images/icons/cool.gif /forums/images/icons/wink.gif
  13. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    You gonna shave it ?Its way easier if ya do it before ya put it in /forums/images/icons/grin.gif
