? for those that have installed a bolt in brace
Discussion in 'The Garage' started by BigCountryx, Mar 18, 2005.
  1. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    I am working on installing my bolt in steering brace from ORD and it looks like the hole that I have to drill is in line with a small bracket that is clamping some hardlines to the crossmember. Have you guys just drilled it out and used the brace to bolt down that bracket, or did you relocate the backet and bolt the brace straight to the crossmember?
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Took the clamp off entirely , threw in corner , put brace on , left lines as is . Lines seem to be fine after a year :grin:
  3. BigCountryx
    Feb 19, 2005
    519
    Gonzales, LA
    Cool, I'll do the same. thanks and BTW where did you get you're shackle Flip Kit from? Never seen one like that before, looks very easy to install. Are You happy with it? How much lift did it give you? Thanks, Scott.
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Was a now defunct "Echobit" flip kit , I picked up used but never installed by the po . I got 5.5 inches from what I gather , never measured . The rear is up just a tad so it sits level severley loaded up .
    It flexes real nice , and I have no handling issues to speak of . I recommend flips , regardless of brand . This one was just easier to install :D
