For those that were curious about 14b welding....~PICS~
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Zeus33rd, Apr 6, 2003.
  1. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Took a few pics while welding NoSmogs stuff today...
    Here's what ya see after ya remove the ring gear and pull the carrier halves apart..
    Here's the spiders welded to the cross shaft. I tack everything together before I actually weld it. Tack the 4 spots that are welded in the picture, take it out, flip it over and do the same thing on the other side...THEN weld it..
    After welding the spiders to the cross shafft, I place the side gear back on top, tacked in in place, took it out, flipped it over, put the other side gear on top and tack that one. Then pull the whole thing out of the carrier and weld at each point where the spiders and side gears meet..16 seperate welds..
  2. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    DUDE YOU ROCK! Thats pretty much what I expected, but seeing the step by step makes it much easier to figure out.
    What are you using? MIG or ARC? I have a 110 MIG and a 220 ARC but I am REAL rusty on the ARC welding. (havent touched it since I discovered MIG over a decade ago) I also have access to a 220 MIG. If your using ARC, what set up and what rod are you using?
    Thanx!
  3. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I use a Lincoln PowerMIG 200....220 wire feed.
    IF I were gonna use a stick welder, I'd use 3/32 or 1/8's 7018 rod. But 7018 is a tricky rod to use well...I've got quite a bit of experience with it. Also, it's a DC only rod, so your machine has to be DC capable.
    You can also send me your stuff to weld for ya... /forums/images/graemlins/thumb.gif /forums/images/graemlins/wink.gif A 14b ff carrier minus ring gear weighs 36lbs. /forums/images/graemlins/deal.gif
  4. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    That is very tempting but Ca is a long way from Fla. If I had an extra carrier I may do that since you have done so many.
    Since your using a MIG that takes a lot of my worry out. Ive been using a MIG almost daily for over 10 yrs. (Im a body man, well not anymore, I "retired" from it a yr ago.) I can MIG good no problem, ARC I was worried about. I was told to use a 220 w/ a 7018 rod sine a MIG wouldnt heat up the surrounding area well enuff for good penetration. Are you using an 023 or 030 wire? Or even 035?
    Ill have to get my rear apart, get it cleaned up and take it to my buddies shop to use his big MIG. Thanx again for the pics and advice.
  5. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I use .035 Hobart ER70S-6 wire with 75/25 mix/Gold Gas. The ER70S-6 is just your basic mild steel wire. Nothin special about it.
    And whoever told ya that a MIG welder won't get hot enuff for good penetration didn't know what they were talkin about. /forums/images/graemlins/rolleyes.gif
  6. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> With 16 seperate weld points plus the spiders being welded to the crossshaft, they could probably be crappy welds and the thing would still hold together. There's way more welding going on with this than in any other weded diff out there, you just can't get into most diffs like you can the 14 bolt... ./forums/images/graemlins/thumb.gif </font>
  7. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Moderators, can we get a thumb tack over here /forums/images/graemlins/thumb.gif
    Thanks, great pics, much appreciated!
  8. MUD JUNKIE
    MUD JUNKIE 1/2 ton status
    Oct 24, 2001
    379
    Reddick,florida
    this is how I welded mine,and I used arc with 7018 rods and 75-90 amps,with pre-heated parts.works very good,I'm glad I did it.good pics /forums/images/graemlins/thumb.gif
  9. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    [/ QUOTE ]That is prob the best point I have heard yet. /forums/images/graemlins/thumb.gif The ARC had me nervous since I hadnt used one in so long, but I am fairly confident in my MIG abilities. BUT even still...I was concerned. Your comment makes me feel that much better. /forums/images/graemlins/grin.gif
    Oh and I got the OK to use my buddies 220 MIG tonite. Now I just need to get it all apart. /forums/images/graemlins/rolleyes.gif
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    How much are you getting to do these if we send 'em to you? I'd like to have you do a FF for me this summer.
  11. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    SWEET! Thanks for the pics! I am going to be welding one up here SOON and this helps alot!
  12. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    Just want to back him up on what he is saying. I own a Miller 210 MIG and heat is NOT an issue. I can burn through 1/4" plate like its sheetmetal.
  13. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I think tonight I am going to take my 14bolt carrier to my friends house and we are gonna weld it up like this. Thanks again for the pics, very very helpful!
  14. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Good luck dude. /forums/images/graemlins/smile.gif Just make sure you pay attention to everything, and TACK everything together while it's sitting in one half of the carrier, and THEN weld it. Other than that...It's a cake walk. /forums/images/graemlins/thumb.gif
  15. nicshorse
    nicshorse Registered Member
    Apr 14, 2003
    16
    omaha ,NE, U.S.A.
    i'm really new at this so this may sound stupid but, why would you do this?
  16. nicshorse
    Apr 14, 2003
    16
    omaha ,NE, U.S.A.
    never mind did a search and at first all i got was every post from folks with "welded 14b" in thier signature. then i tried all of the different words and got in essence "to lock it up"
  17. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    Its to make the rear axles lock up. Like a spool. There is no spinning 1 tire in the mud or if you lift a tire the one off the ground spins leaving you w/ no traction this way. If 1 is turning the other is unless you break an axle shaft which is pretty unheard of.
    The down side is turning tight corners on pavement.
  18. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    It's the cheapest way out there to get traction. A Detriot is $300+ and has "predictability issues" A welded rear is basically free, and has no wierd driving characteristics or noises. Like PI said, The only downside is the slow speed corners- Makes alot of chirping noises and is hard on tires. /forums/images/graemlins/thumb.gif
  19. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Well mine is done. Looks just like the pics, but we put more weld in the corners of mine. Already put it back in the carrier, so no pics...sorry /forums/images/graemlins/frown.gif
