for those w/ Hummer beadlocks
Discussion in 'The Garage' started by bigjbear, Sep 27, 2002.
  1. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    I am seriously thinking of this. I don't know what would be better; modified center or or unmodified on a dually front. Or would I be better served using another type beadlock. I am leaning toward the dually front for cost reasons and simplicty, the rear will be easier to correct than the rims. I am looking for both mod and unmod'd opinions.
    If you have some pics of them mounted I would love to see them. Let me know if they are stock centers or mod and tire size, too.
    TIA
  2. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    The nice thing about modifying the centers is you would be able to use other rims, if need be. I have also wondered about using the new chevy aluminum rims w/dually hubs. It looks like the offset is about the same.
  3. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    I am installing my front axle tonight and by Sunday I should have pics of the Humvee wheels on duelly axles(but I do not the spacers for the back yet).
  4. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Cool, anyone else? I've been spending some quality time w/ the search function on POR and may have a solution for the rear. Run the Hummer rims backward. That gives 2.5" of backspacing if they are realy 9.5" wide. How does that sound? The only concern I can think of is the loss of an acorn seat. One could use two nuts per stud. I'm not sure if I like that idea though.
  5. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    run them backwards and remeber to check the regularly, or you can mill them the other direction so the acorns seat.
    i think that was what you were saying....
  6. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    You got the idea. I was worried if I tapered the back side it might make the metal too thin at the seat.
  7. blazen91
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    I plan on just getting spacers to even out the wheels. That way everythig will work as it was designed. Also with the HUGE full floating hub sticking out of the d70, the spacer will help hide that from the rocks. Just my opinon, and you all know what those are like!! /forums/images/icons/tongue.gif
  8. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    I had planed on doing the spacer thing as well. I may mount them backward just to see how it looks then make up my mind. Did you have any problems with the fit? Are you running stock stubs or 35 spline? Do you know if the stubs are the same as the SRW? Looking forward to the pics.
    Again,TIA
  9. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    Would it be OK to use the hummer wheels with spacers in the front? On my dream Burban I was planning on keeping the stock axles for a little while and running the hummer wheels with spacers until I can afford my dually axles ;-)
  10. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    I put some on backward for a test fit once. They stick out about 2" with 36x12.5's. I didn't see a problem with the lug nuts.
  11. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Was that on the rear axle or the front?
  12. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Anyone know if SRW & DRW fronts use the same stubshaft?
  13. blazen91
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
  14. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
  15. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    yup and LOOKY JIM IS ORANGE /forums/images/icons/shocked.gif
  16. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Blazin, that is exactly what I was looking for. Thank you. I assume no problems w/ the center hole? I got my dually stuff lined up today and have a line on the rims.
  17. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    tom & beater thanks for the info. That was what I was hesitating on.
    Beater, I need to change sig line now /forums/images/icons/cool.gif
  18. blazen91
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    No problem, check back in a week or two and I should have the body on the frame. No problems with the center hole. Just bolt and go!!
  19. beater74
    May 29, 2001
    1,749
    atlanta
    [darth vade voice] i knew we could get you join the orange side [/darth vader voice] /forums/images/icons/grin.gif brake something at dixie for me.
  20. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    I probably jinxed my self buying the 1 ton stuff & going up there 1/2 ton!
