For Those wanting to go to Hydraulic Clutch...*PICS*
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Tommy, Nov 24, 2001.
  1. Tommy
    Tommy 1/2 ton status
    Feb 21, 2000
    260
    Alabama
    I'm in the finishing stages of my 4 speed swap, and had to share abouth my hydraulic setup I put together. I have read several posts, and I was dreading it, but I wanted a hydraulic setup. I noticed a manual 91-93 chevy truck when I picked up my tranny at junkyard, seen the slave-master setup, thought it would work, the guy only wanted $20, so what the hell. I made a bracket out of 3" angle, 1/4"thick, that bolted onto the bellhousing with the pivot stud hole and the two side bellhousing bolts. I welded two straps to the angle to bolt to the two bellhousing bolts. I had to cut the line, it was a mile too long, and bought a 8" line at parts store to use as couplings to solder line back together where I cut it. I was amazed how easy it was. I have a grand total of $22.95 in my hydraulic setup. I tried it this morning, works great, I still have some fine tuning on the pedal ratio, but its gonna work. I will post pics later, just had to tell so those who are wanting this can start fabbing.
    <a target="_blank" href=http://community.webshots.com/user/tommy69z>http://community.webshots.com/user/tommy69z</a>
    They didn't come out as good as I wanted them to. If you have questions maybe I can help. I should have taken pics before putting it on. Been driving around couple of days, seems to work great.
    Drive it Like You Hate It!<P ID="edit"><FONT class="small">Edited by Tommy on 11/28/01 08:58 PM.</FONT></P>
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
  3. JoshA
    JoshA 1/2 ton status
    Apr 9, 2001
    104
    slc,ut
    Re: For Those wanting to go to Hydraulic Clutch...
    I am VERY interested in this. please post the pics when you get them.
    '72 blazer 9" lift YOKO mudders 35x12.50 350/sm465/3.73 UTAH
  4. jmeador74
    jmeador74 1/2 ton status
    Oct 31, 2001
    108
    Eatontown, NJ
    Hey Tommy its great to hear you got you got the tranny in... is the truck running again? Hey man... let me know if you still wanna do the fuel tank swap... still?
    72 Chevy Blazer, 327, SM-465, NP 205, 4in lift, 35 in tires
    Was About to put in 400 SBC/ 700-R4
    Now trying to go 454/ 400/ 205 setup
  5. Tommy
    Feb 21, 2000
    260
    Alabama
    I do wanna swap on the tank, its just not high up on the get things done list. I just have too much going on, I'm trying to get an AC buisness started, thats my first priority, but yes I do want to swap. Tommy
  6. Does the hydraulic setup do for the clutch feel what power brakes does to manual brakes? Looks like a great project, but I'm not familar with what exactly a hydraulic clutch setup gains you.
    1969 C20 4x4
    4" lift, 35x12.50x16 Super Swamper SSR's
  7. Tommy
    Feb 21, 2000
    260
    Alabama
    In my case it made the swap easier, it also takes the flex problem out of the picture. I just didn't want to fool with the linkage since I had a body lift.
