For those who are runnin 40's?????????????
Discussion in 'The Garage' started by BamBamblazer, Mar 6, 2004.
  1. BamBamblazer
    BamBamblazer 1/2 ton status
    Jun 24, 2002
    486
    McCordsville, Indiana
    For those who are runnin 40\'s?????????????
    I am getting ready to do the axle swap and put on my 39.5 irok's and i have a question. Did you leave your front axle in the stock location or did you move it forward with a zero rate? I just dont want to get it in then have to take it all apart to install a zero rate so it wont rub the fire wall! Also on a side note, will a zero rate, setting the axle back 1.5"s be enough correction on the rear when i do a echobit flip and go from 10 bolt to a 14ff?
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    Re: For those who are runnin 40\'s?????????????
    i have mine in the stock location /forums/images/graemlins/thumb.gif
  3. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    I think this all depends on how much lift you have. I'm running 39.5 tsl's but I only have 4" BDS springs and have the zero rate in there moving it an inch forward and I think its just right for my truck.
  4. BamBamblazer
    Jun 24, 2002
    486
    So you have no rub issues at the firewall when stuffed?
    That is what i wanted to hear!
  5. desertrat67
    desertrat67 Hawk Driver
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    If i hit really hard in the front, my 38s would hit the rear. i moved my axle forward 1 1/4" and have not had a prolem since. this is with a D60 and 6"-7" lift.
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i only have 2.5in lift /forums/images/graemlins/eek.gif so yes if i flex it out hard they will rub but under about half flex to maybe 3/4 flex they don't rub /forums/images/graemlins/eek.gif /forums/images/graemlins/thumb.gif now as soon as i get my 4in lift on i should be able to flex way more /forums/images/graemlins/thumb.gif
  7. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I have a D44 with 4.5" of lift. At full stuff my 37's rub the firewall on both sides. I got a D60 comin in and we'll see if it gets better. I am going to 40's in the summer and will use a z-rate to avoid the firewall. As for the z-rate to axle change height, I can't sat. A D60 in the front will even out a 14FF in the rear. So you kinda break even.
  8. scoutillac
    scoutillac 1/2 ton status
    Feb 24, 2004
    423
    Spokane, Wa.
    I am hearing alot about those zero rate springs. What are the best ones to look at? How much are they?
  9. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I ran 40's with 4" lift and sagging body mounts. Under a hard, hard compression, the would hit the firewall. On the last hit, It tore the body off the mount. but they were toast anyways!
  10. tRustyK5
    Jul 23, 2000
    36,180
    1,387
    E-town baby!
    I moved my D60 forward 1 1/4" without using a zero rate. My 40's don't hit the firewall/floorboard area at full stuff and turned. I re-drilled the perches and clearanced the spring plates to move the diff...I didn't want more lift.
    Rene
