for those who did the shackle flip through the hanger....
Discussion in 'The Garage' started by supersize75k5, Feb 23, 2004.
  1. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    did you have drive line vibes? Shims? If so what degree did you go to, the 83' had the 4 speed/208 combo and 10 bolts.
    Thanks,
    shawn /forums/images/graemlins/ears.gif
  2. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    I have the shackle flip and I am getting some Vibe. I dropped the Tcase down and had my drivelines lengthened so now I am wondering what degree shims I will need. /forums/images/graemlins/thinking.gif
  3. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    how do you know you have vibe
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    No shims or vibes. I do have the CVC in the back though. The angle worked out well with just lowering the rear of the spring.
  5. shaun
    Apr 22, 2003
    745
    Because when I apply throttle I can feel a slight vibration. And if it is all quiet and no radio it sounds like a bass tube inside the truck?
  6. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,092
    489
    Grand Rapids area
    The best combination I have found is 6.5 degrees down on the rear pinion and about a 1.25" T-Case drop. This is still pushing the limits of a stock length 2 U-joint shaft. My U-joints are both at about 13 degrees. I still get slight vibrations sometimes (my wife can not notice it), but I have tried several combination and this is the best I can get it without a slip yoke eliminator or CV shaft. My U-joints are lasting forever, too.
  7. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    I had vibes BAD and then dropped the t case and they went away. Have done some power adders (duals, intake, tossed the ac) and now under some acceleration from a dead stop, I get a little vibe, but it quickly subsides. Pinion angle is perfect for a CV.
    John
