For those who have converted to R134...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Corey-88K5, May 9, 2000.
  1. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    Sorry for not putting this on the other post, but I was just wondering what the cost was in the conversion. My compressor was replaced 2 years ago, so it must have some bad seals somewhere. What would I be looking for as far as the conversion? Do you need to have the system evacuated and dried before the conversion?
    Thanks,
    Corey
    88K5
    [​IMG]<font color=red>Girls Like Guys In Bow Ties
    http://www.geocities.com/corey_perez
  2. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    You can buy the kit from a parts store for about 40.00, plus replace the orfice while you are at it.And you might want to replace the o-rings, while you are at it. Once done, get someone to pull a vacuume on it then fill it with the 134...
    <font color=green>[​IMG]Eagle86K5[​IMG]<font color=red>
    Masonry...It's a Good Thing
    2B1ASK1
  3. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    Autozone has the kits and Harbor freight had a vacuum on sale for 9$ I should have replaced the drier and orifice but didnt but its working great it sounds loud at idle I think my pump is going but til then its seems good.
  4. 6.2 man
    6.2 man 1/2 ton status Premium Member
    636
    Curtis , WA
    Eagle gave some good info on the system . Something else to think about is R12 is hard to get and cost more than 3 times more than R134 . It's worth the money to convert .
  5. bart
    bart Registered Member
    Mar 15, 2000
    69
    Eastern PA
    As the oil used in R12 systems is different from that used in R134A systems you should change the o-ring seals if at all possible...there is a "flush" that you can use in the system if you so desire...If your system was ever left "open" at some time or another then change the drier.
    Just dump all the old oil out of the compressor...if there is any left and follow the instructions with the kit.
    R134A costs less than $40 for a 15 lb cylinder...gauge set is about $40 or so...then you need a scale to do it right..if you don't have a vac pump, run the vac side of the manifold gage set to your intake vac port...you'll at least get it down to about 11 inches...just hold it for a while..check for leaks...if none, charge up...Don't overcharge the r134A as it operates over a wider P-V curve...a higher system pressure...
    you lose some cooling capacity using R134A in a system designed for 12..but mine has worked just fine for two years now. If you find that your system is taking a long time to take the full charge, and it's a hot day...get out the garden hose and hose off the evap. while charging...
    Sorry for going on so long.
  6. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    I'm not sure if I posted this link already, but here it goes: http://www.aircondition.com/
    Hope it helps you out.
    <font color=black>//////
    What the heck!...Drive it like gas is $0.50/gal!!!
    </font color=black>[​IMG]
  7. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    Just got the LMC Blazer/Jimmy catalogue in the mail yesterday. One word - AWESOME!!!! Read it 3 times cover to cover.
    They have an R134A conversion kit for $29.95!! (P.56) I don't know if this is worth a pinch or not but it's cheap.
    Comments?
    Brian
