For those who have used the roll on bedliner...
Discussion in 'The Garage' started by BlackDog714, Nov 21, 2003.
  1. BlackDog714
    BlackDog714 1/2 ton status
    Jun 8, 2002
    260
    Indiana
    In your cab/passenger compartment. How do you keep from covering the bolt holes?
    I am covering the floor with the Duplicolor Bedliner and then putting carpet over that.
  2. got_mud
    got_mud 1/2 ton status
    May 9, 2003
    316
    Wichita, KS
    put all the bolts in halfway and wrap them with masking tape
  3. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    I took pieces of masking tape and rolled then into a cone shape so the sticky is on the outside and stuck 1 in each hole. It worked fine.
    Will
  4. jms
    jms 1/2 ton status Author
    Jan 24, 2001
    1,683
    Ditto.
  5. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    Duplicolor Bedliner
    i had a big problem with it it never got hard and i had to clean it out and the people at the teck hot line could not help me
    i went with the hurh just last weakend
  6. BlackDog714
    Jun 8, 2002
    260
    Indiana
    Duplicolor Bedliner
    How did you clean it off and how big of a mess was that???
  7. ramjet gmc
    Dec 19, 2001
    3,370
    it was like cleaning up oil wiped it up with rags and then carb cleaner and then dish sope
    it was not bad but hurk is on sale this week at pepboys
  8. BlackDog714
    Jun 8, 2002
    260
    Indiana
    Anyone else have this problem????
    No PepBoys around here /forums/images/graemlins/frown.gif
    Schuck's sells the Hurculiner, its just double the price...
  9. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    Order it online then...
  10. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I used the hurcliner. I covered the holes with masking tape. Then went around with a nail untill I found the holes..
  11. BlackDog714
    Jun 8, 2002
    260
    Indiana
    But is the Hurculiner THAT much better than the Duplicolor??? Its not going to be seen, I'm mostly using it as a sound deadener(sp)... The liner with carpet pad and carpet over it should be pretty quiet.
  12. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    I used the Duplicolor on mine and didnt like it, it got hard after 3-4 days but all it is thick paint, it gets the texture from the roller you will use to put it on, also i still had to put down floor mats and there are still patches showing from my feet /forums/images/graemlins/mad.gif
  13. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    masking tape.
    also, hate to break it to ya, but herc/dup dont sound deaden for crap. I had my interior stripped for a couple of weeks.. and then I installed herculiner... several coats, nice and thick. There may have been a difference in noise level that you could measure with a decible meter... but to my ears it didnt get much, if at all, quieter after it was coated.
    guarding against rust, durability and easy-clean-up are good reasons to apply a liner... sound deadening, not so much... unless you pay the extra $$$$ for Line-X or Rhino. I'd highly recommend one of those if sound deadening is what you're looking for.
    j
  14. I put the Herc in my Sub and does not sound deaden. It will actually make it echo until you put some carpet or something in. After the Herc, I put down a layer of Brown Bread (like dynamat), then insulation, then a new vinyl floor. Made a huge difference, much quiter.
    Mat
  15. BlackDog714
    Jun 8, 2002
    260
    Indiana
    Should I even bother with the bed liner stuff at all? I plan on running carpet until the summer anyway (top comes off then!!!). Maybe I should just POR15 the bed area (all the surface rust has already been removed in prep for the bedliner. I already have the bedliner stuff, but I can return it...
  16. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    As long as you have it I would use it. I lined my entire interior compartment. I also use carpet but if the carpet gets damp the liner should provide a good barrier for the sheet metal. When you remove your carpet you will have a nice durable finish already there.
  17. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    if u want sound deadening, return the bed liner you got and save until you can afford Line-X or Rhino... if you want rust resistance and easy cleanup, install the bedliner ya got.
    j
