for those with 40+ tires and decent to wild flex
Discussion in 'The Garage' started by basing110, May 27, 2006.
  1. basing110
    basing110 1/2 ton status
    Aug 4, 2005
    298
    san diego
    for those with tires bigger than 40" and have decent to wild flex.lets see some pictures of your rigs .. i want to try and compare to see how mine looks compared to yours ... i wanna see how my suspension compares and fittmant of tires fit in the wheelwell compressed and drooped compared to yours . ill have some pics up of my truck later on today ..hopefully me and my freind will get the 30deg flex ramp done .. but if not ill flex it out as much as a local rock pile will let me .. my k5 specs are 2" lift 52's with overload removed up front with a zero rate to move axle forward an additional 1.5" and custom made 7.25" shackles ,moved shackle hanger mount up additional amount to get my shackle angle right,all poly bushings. rear is stock 56" springs with overload flipped upside down and springs backwards,2" zero rate to move axle forward the 1.5" ,4" ord shackle flip swapped sides with 6" ord rear hd shackles,all poly bushings
  2. basing110
    Aug 4, 2005
    298
    san diego
  3. basing110
    Aug 4, 2005
    298
    san diego
  4. basing110
    Aug 4, 2005
    298
    san diego
  5. basing110
    Aug 4, 2005
    298
    san diego
  6. basing110
    Aug 4, 2005
    298
    san diego
  7. basing110
    Aug 4, 2005
    298
    san diego
  8. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    umm...you can post more than 1 pic per post... Looking good though!
  9. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    what you run for your suspension it looks good
  10. jackedjimmy350
    jackedjimmy350 1/2 ton status
    Oct 20, 2000
    3,141
    Fort Smith, Arkansas 72901
    yeah sweet, how bout some stats
  11. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    This is Koldsimer's blazer. And the exocaged blazer is Leper's.
    Koldsimer gets 54" of flex without lifting a tire.
  12. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    yeah his is nice
  13. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    Basing110, are those 39" Boggers? No body lift, right? Any side pics of it at rest? I'm going to run a similar suspension with 42's and would like to see the stance.
  14. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    Here are a couple from last year, I still havent found the "max" but i like it, stock springs all the way around, ORD flip in back, with 39.5" TSLS
  15. basing110
    Aug 4, 2005
    298
    san diego
    i have 44" boggers ... koldsimer gets one of his tires 54" off the ground without lifting a tire? yea i cant wait to max mine out on the ramp after i finish getting it built
  16. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    yeah that looks pimp so whatcha got for susp i run 44's and i want that flex i got
    6" tc ez rides up front
    6" echobit flip rear stock rear springs
  17. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    punk, look at more than jus the pics! :p:
  18. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    oops lol i think i might need to redo some stuff on mine lol
