? for those with a 454 and a TH350
Discussion in 'The Garage' started by 70~K5, Jul 13, 2004.
  1. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Which tranny dipstick tube did you use. Mine has a 34" like was used with the smallblock. The tube is hard against the back of the right side valve cover. Made it real hard to install the bellhousing bolt with the tab on the tube today when I changed the O-ring seal that was leaking.
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I had that problem too. I bent the tube back.
  3. wasted wages
    wasted wages 3/4 ton status
    Dec 3, 2003
    9,194
    Dallas Texas
    With a big block and a T-350,,,,don't worry about bolting it up it,,,,, the trans won't last that long!!!! /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif
  4. 85 blazer
    85 blazer 1/2 ton status
    Feb 12, 2002
    118
    Avoca NY
    mine has had the shi! beat out of it with a modded 454 and no troubles of course me and my best friend built the tranny!!!!!!!!!!!!!!!!!!!!!
  5. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    I've been running that set up for years(i have a th400 waititng to go in) and yes I wheel it!
  6. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    Would switching to the shorter 27" dipstick and tube solve the problem? I know some chevy trucks came with a TH350 and a big block, maybe not as common as a T400 behind a 454, but a friends father bought a '77 K20 new that had this combo. What did the factory do in this case? Did they have a different tube or what?
  7. 85HeartBurb
    Jan 10, 2002
    735
    Temecula, south
    Don't know mine is fine but it came that way from previous owner sorry..
