? for those with big blocks
Discussion in 'The Garage' started by GRAYTEXK5, Jul 14, 2004.
  1. GRAYTEXK5
    GRAYTEXK5 1/2 ton status
    Jul 23, 2002
    281
    Ft. Worth, TX
    for those of you that have big blocks in your K5's...did you have to use different frame stands, or did it just bolt in? and what headers did you use? I talked to summit and jegs, and was thinking about some hedman elite headers...and they both said I have to get factory big block frame stands. is that true, or will they clear without them? just trying to find out what kinda problems I may run into, before I decide what to buy. thanks.
  2. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    My big block bolted right in with the factory small block motor mounts. I have headers off a 1978 nova on mine, but I can not say for sure that they would work for you as my frame may have be modified for them to fit. /forums/images/graemlins/dunno.gif
  3. islandblazin
    islandblazin Registered Member
    Jul 14, 2004
    7
    P TowN
    I have a 396 mounted onto a 350 small block mounts in my 72 blazer and it works great. except i had to cut the fan gaurd a little cause the belt rubbed a bit.
  4. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Mine bolted right in too using the small block mounts. I think the only difference is the small block mounts might make it sit up a little higher.
    As for headers, I running Hooker Super comps made for a big block blazer
  5. GRAYTEXK5
    Jul 23, 2002
    281
    Ft. Worth, TX
    what kind of headers are you running, if any? I think what they were saying, was that I needed the frame stands for those particular headers. they said the hookers didn't say anything about it. but I was wanting to go with the elites, because they were cheaper.
  6. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    mine are headmen comps
  7. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Mine are the full length stle like the ones pictured only ceramic coated and covered with mud /forums/images/graemlins/frown.gif
  8. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    What year K5 are you talking about?
    I put a big block in my 69 K20 using the 69's small block motor crossmember but had firewall issues. I used Dynomax 67-87 2WD BBC headers fit, part number 86022 with a little frame grinding on the passenger side. Driver side fit perfectly.
  9. GRAYTEXK5
    Jul 23, 2002
    281
    Ft. Worth, TX
    it's a 79
  10. 85 blazer
    85 blazer 1/2 ton status
    Feb 12, 2002
    118
    Avoca NY
    I used dynomax headers for a 2wd and the stock small block frame mounts withe the 454 engine mounts no problems at all
